Old 12-04-2002, 01:46 PM
Presto Presto is offline
what kind of paints should i use to paint my bit body?
what kind of paint should i use to paint over my stock bit body? how about a clear body?
any special methods you would recommend?
Red FD3S
Old 12-04-2002, 01:52 PM
aero aero is offline
What It Is To Burn!
on a clear body i recomend painting the inside, so if you run into something, you won't scratch or chip the paint, plus you can make it look cool
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
Old 12-04-2002, 02:46 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
TO answer you first question, i use testors and it works fine. I would suggest to use spray paint or an air brush and just tape the spots that you dont want painted. To answer your second question, i would suggest painting on BOTH sides of the paint, it gives it a little bit more shiny loo,. And i would also suggest that u use gloss, and you probably would definetly need it on the inside so the paint wont rub off against the chassis. Hope that helps.
-----My Mini R/C Site-----
Old 12-04-2002, 03:00 PM
thank you!!!
Red FD3S
Old 12-04-2002, 03:13 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
this has been talked about alot...
but i prefer to paint on the inside with dark colors, and metallic and anything normal or light colored on the outside...
i prefer to use Tamiya paints because its more durbable, and doesnt come off if you scratch or hit something.
Old 12-04-2002, 06:55 PM
seizurebot[rdf] seizurebot[rdf] is offline
color markers and sharpies are the best, i color lizards on my arms sometimes
RDF 4 LiFe
Old 12-04-2002, 11:30 PM
SUPRAstar's Avatar
SUPRAstar SUPRAstar is offline
JUST BRING IT
well i just sprayed mine with primer on the outside and gave it a lite sand.i went to autozone to check the colors they have and i found the coolest paint.it's that mystic paint that changes colors like on the mustang cobra's.so i should have it painted in a couple of days i'll keep you posted
Old 12-04-2002, 11:34 PM
i tried spraying it with an airbrusher, but it killed it - so i just hand paintedthem with testor's paint and it owns now, i will post pics later :bigthumb:
Red FD3S
Old 12-05-2002, 01:25 AM
boostmonger's Avatar
boostmonger boostmonger is offline
hot rodding maniac
Send a message via AIM to boostmonger
i painted my yota with that duplicolor mirage paint.i used the gold/magenta, and it came out dope looking.you just have to do like 5 or 6 coats of the paint before the clear.
2xMicrosizers
6-Clones
1 mini-z
1 xmod
More and more mods everyday
Old 12-05-2002, 01:27 AM
do you have pics? where did you get the paint?
Red FD3S
Old 12-05-2002, 01:52 AM
hot rodding maniac
i got the paint at wal-mart.i don't have a real good pic, cause my camera is a p.o.s.but here's one anyways.
2xMicrosizers
6-Clones
1 mini-z
1 xmod
Old 12-05-2002, 01:54 AM
hot rodding maniac
the color actually came out real dope looking.when there's no direct light on it, it's like a burgundy, and when light hits it directly on, it changes to a copperish bronze color.
2xMicrosizers
6-Clones
1 mini-z
1 xmod
Old 12-05-2002, 07:27 AM
xXx_Vegito_xXx's Avatar
xXx_Vegito_xXx xXx_Vegito_xXx is offline
Thumbs up
it looks nice. i just started painting mine but i couldn't get all the paint off but i got most of it off. i'm painting it black with red flames i'll post my progress
Specs
custom paint
Honda s2000
3.0 motor (came as stock motor)
medium tires
Old 12-06-2002, 03:45 PM
SUPRAstar's Avatar
JUST BRING IT
here's what the mystic paint job looks like.let me know what you think. BTW these pics don't do the paint job justice.it looks ten times better.
Old 12-06-2002, 03:47 PM
SUPRAstar's Avatar
JUST BRING IT
here's another
Modifying the bit body Mark Bit Char-G Mods and Projects 3 10-22-2004 05:33 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Chameleon paint bit mbplt Bit Char-G Gallery 7 09-28-2002 03:12 PM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 07:28 PM
what is a good paint brush to use on Bit Char-G? 323iT Bit Char-G / MicroSizers 1 06-02-2002 02:07 PM
