Old 12-03-2002, 11:01 PM
anthonyb45
anothner problem another car
gear axel slides out really esay so when its on the ground it judt spins the idle gear can i fix it
Old 12-03-2002, 11:37 PM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
Try a small drop of crazy glue or epoxy to get the gear back on the axle. If you have put some kind of lubrication on the gear, make sure you clean it all off before you start. Just remember to take the axle out before you try to use any adhesive on your bit.
Z car transmission problem? rikc Atomic Z-Cars 0 02-21-2005 11:59 AM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
new car, slight problem jamgunner ZipZaps SE 11 08-29-2004 08:44 PM
Intermittent problem. marc_w Bit Char-G / MicroSizers 7 03-07-2003 12:33 PM
Charger Problem snakeman65 Bit Char-G / MicroSizers 10 10-31-2002 03:35 AM
