Old 11-29-2002, 09:43 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Exclamation Make your car faster.....FOR FREE!
Ok, Take off the gear on the motor, and the idler gear. Put the idler gear, ON BACKWARD on the motor. Put a piece of paper inside the gear so it will grab the motor shaft. The gear SHOULD touch the one attatched to the axle, and it should go faster. Only one thing changes, instead of pressing the forward button to go forward, you have to press the backward button. Trust me on this one, it makes your car MUCH faster.
Pros-car goes faster
-faster top-end speed
Cons-slower accelleration
-takes too long to slow down
-have to recharge more often
You HAVE to try this, it is easy to do, and makes your car faster, FOR FREE! Oh yea, and without wrecking anything
Old 11-29-2002, 09:47 PM
xatu's Avatar
Here is a pic of it:
xatu's Avatar
And another. Please tell me if this is a good/helpful mod also!
Old 11-30-2002, 01:47 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
i have thought about this a while back..but didnt do it...
i just thought that if i didnt use the idle gear itself, it would be a silent car...hehe..
btw..does the paper stay in really well?....i would have tried to glue one on....
Old 11-30-2002, 11:35 AM
xatu's Avatar
I tried glueing it on, but that didn't work because the hole in the idler gear is larger than the axle on the motor, and it will be crooked when it dries. The paper holds AWESOME, and doesn't slip a bit!
BTW, another fun thing to do, take the motor out of your car, give it a big push, and when it gets really fast, turn it to the left or right.
Old 11-30-2002, 12:22 PM
Reckless44 Reckless44 is offline
What do you mean by put the paper inside the gear, and how do you do it?
Old 11-30-2002, 12:36 PM
Sykoracer02 Sykoracer02 is offline
Send a message via AIM to Sykoracer02
did u cut any thing?
Ae86(Trueno)
3.8
Gear 9.86:1
Tire Soft
Rx-7fd(Rx-7)
3.8
Gear 9.86:1
Tire Soft
Old 11-30-2002, 12:45 PM
xatu's Avatar
Ok, here, I'll show you how. (You just put a small piece of paper inside the gear)
Here is what you will need:
Old 11-30-2002, 12:46 PM
xatu's Avatar
Pick up the small piece of papr with the tweesers, and insert it into the gear. (you may have to put a larger piece of paper in, it may be too small)
Old 11-30-2002, 12:47 PM
xatu's Avatar
Then just place it on the motor axle, and it works. (the piece of paper I used in the picture was too small, so it didn't work right)
Old 11-30-2002, 12:49 PM
xatu's Avatar
It doesn't matter if the paper is sticking out of the end of the gear, it is normal, and don't cut it off! I did, and the gear just fell off. And put the paper in the gear through the end with the smaller gear! Or else it won't go one right.
Please tell me if this works for you!
Old 11-30-2002, 01:07 PM
it sill dose work. Dose your work? can u send some pic of how you put it in your car.
Ae86(Trueno)
3.8
Gear 9.86:1
Tire Soft
Rx-7fd(Rx-7)
3.8
Gear 9.86:1
Tire Soft
Old 11-30-2002, 01:17 PM
xatu's Avatar
It can't get much simpler than what it is in the pictues I posted, sorry.
Old 11-30-2002, 02:28 PM
i got it to wrok for a little
Ae86(Trueno)
3.8
Gear 9.86:1
Tire Soft
Rx-7fd(Rx-7)
3.8
Gear 9.86:1
Tire Soft
Old 11-30-2002, 02:31 PM
xatu's Avatar
Good! Do you like it? I mean, it gives you lots more speed, I'm sure it would work MUCH better with 2 batteries... I am getting an idea here
wanna make your mini X faster? MicroRCEngineering Mini-X Parts and Hop-Ups 7 04-15-2003 08:34 PM
Can I make it Faster? BigC Atomic Z-Cars 3 01-01-2003 05:33 PM
car reverses faster? DioXidE Bit Char-G / MicroSizers 13 12-28-2002 02:49 AM
my car goes faster backwards billdill Bit Char-G / MicroSizers 10 08-15-2002 06:06 AM
For A Faster Car bOdYRoC Bit Char-G / MicroSizers 4 06-21-2002 08:34 PM
