Old 11-06-2002, 11:13 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
speed control?
okay i am bored and thought about using a slide controler like the old lap tops have for the contrast or even a rotary dial to control the speed, my idea is if some how one was rigged up could and would it be posible to control the foward reverse with the thumb and with the index finger slide the dial to control speed i have no electronic know how and want to toss this out there
also if it has been covered just direct me cause i couldnt find it in the search
Old 11-09-2002, 09:26 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
Re: speed control?
um...with R/C you gotta send a signal from the radio to the car..and the car gots to receive it...so putting an extra button on the controller isn't gonna do anything, you gotta have it send a signal to the car, which the electronics on the car have to receive...if you can get that far, you can do pretty much anything...just make sure you let the FCC know what frequency you plan to use so you don't piss off you're neighbors.
Old 11-11-2002, 09:58 PM
wild03 wild03 is offline
Re: Re: speed control?
Hmmm!!! What about a pure mechanical solution, well sort of, one could use the forward/reverse to control a screwdrive type setup, similar to the one that moves the heads on a 3 1/4 floppy drive, just a LOT LOT smaller. anyways this will move a resistor type speed control that could feed the wheel motor from an independent battery.
SO you would tap forwards to move slow then tap again to go FASTER, and so on.
Old 11-11-2002, 10:28 PM
Steve's Avatar
zipped up tight!
I attempted to do something similar to what you describe, however, I found a clone that already has two speeds, which basically made my idea obsolete. That doesn't mean you shouldn't try something new though, you never know.
Old 11-12-2002, 04:26 PM
crutial crutial is offline
hmm
hmm.....the zz sends power to the motor with transistors that turn fully on or off, and its not Pusle Width Modulated, I checked it on my scope. There is one way you might be able to do it. Pulse width modulate the foward and reverse buttons, this way the signal to the car will PWMed and you will have a very nice and smooth speed control. Anyone interesed on how to do this, its pretty easy and you can get the parts from radio shack. I think im going to do this, its going to be cool.
Old 11-12-2002, 07:53 PM
Steve's Avatar
zipped up tight!
Re: hmm
Please share! I think I grasp the concept, but not sure how you plan to implement it.
Old 11-13-2002, 09:25 AM
Re: hmm
Talk about Turbo LAG but it could work! as long as the delay is not to big I can see that you could just can keep tapping forward
in the curves....It might be harder that just swapping transistors since I've seen people go to great lengths as to adding a delay board with variable resistor to control the timing to do this same thing!
Old 11-13-2002, 02:56 PM
Steve's Avatar
zipped up tight!
Re: Re: hmm
Yep, I tried to add the variable delay circuit, but I couldn't find a relay that would work with as little as 1.2 volts. I havn't shelved the idea yet, I just need to research a little to see if there is another way.
Old 11-13-2002, 05:13 PM
Re: Re: Re: hmm
Couldn't you use a transistors intead of a relay? I'm no expect but aren't transsistors like an electronic switch?
Old 11-13-2002, 06:37 PM
Steve's Avatar
zipped up tight!
Re: Re: Re: Re: hmm
Well, that's the definition I guess, but I don't have any idea how to use them...anyone...anyone...Bueller?
Old 11-24-2002, 10:04 PM
ejaf ejaf is offline
dual speed car?
Steve,
What car do you have that has dual speeds? Could you let me know the FCC ID on the back of the controller? I would like to compare that with the ZZ controller schematic.
TIA
Old 11-25-2002, 10:57 AM
Re: Re: Re: Re: Re: hmm
Steve, I used a transistor switch on my mod, maybe you can use the same idea for yours, I basically use the 1.3v that drive the stock motor to close the transistor and send 4.5 volts to a pager motor.
IT might take a while to access my page, Seems I exceeded the data transfer
minidragster
Old 11-26-2002, 08:13 PM
Steve's Avatar
zipped up tight!
excellent. I've been in Buffalo all week working, but now that I'm home I'll have some time to play. Thanks for the link, nice write up and pics.
Speed & Steering Control hschnark Bit Char-G / MicroSizers 2 03-09-2006 06:39 PM
SE 1/4 mile speed tests Steve ZipZaps SE 8 02-08-2006 03:04 PM
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 01:21 AM
The Infinite Speed Potentiometer Mod (tm) actofgod Bit Science 46 09-16-2003 05:47 PM
Mods for Zipzaps: Speed & Control ~SnakeBitRacer~ Bit Char-G Mods and Projects 1 02-17-2003 12:15 AM
