Old 11-24-2002, 01:44 PM
tiki_spirit tiki_spirit is offline
Reception
Is there anyway to get my ZZ to go further without losing its reception? I've heard of using copper wire. However, I'm not too good at soldering. Any suggestions?
Old 11-24-2002, 01:52 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Have you untied the knot underneath the board and pulled it up thru the front yet? This'll give you a longer antenna and an additional 3-6 feet. When you pull the antenna out the front of the body, make the hole where a regular car antenna would be. Gives it a nice FX.
Next thing you can do is take an old cordless or remote control car antenna and replace the one on the zips controller. This'll take some handy work if you don't want to solder.
Also, if you like modifying, look on the internet on how to solder and find some old PCV boards and practice. You might have some lying around from old PC's etc... Soldering is an art, but with a lot of practice is pretty easy to learn.
One more thing that I'm still guilty of is touching the antenna with my finger when driving. This will decrease your range as well.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 11-24-2002, 03:56 PM
Ok, I plan to put the antenna up through the front. Also, I was messin around and coiling a thin piece of copper wire improved its range by about 20-25%. Anyway, how would you replace the antenna on the controler? Any website that says how to?
Old 11-24-2002, 04:25 PM
Go0ty's Avatar
Go0ty Go0ty is offline
funk master flex
Send a message via AIM to Go0ty
replacing the controller antenna is extremely easy. just unscrew the case and you'll see how easy it is. there's a little screw at the end of the antenna that holds it into place and a little metal piece that simply has to make contact with the antenna. just unscrew the screw and take out the antenna then screw a new antenna in (find an old TV antenna or something if you don't want to go buy a new one), then place the metal piece in contact with your new antenna then screw it all up and voila
Old 11-24-2002, 04:47 PM
It doesn't look easy! There's still 2 wires holding it together and the screw/controler will only take an antenna of a certain size. Any suggestions?
Old 11-24-2002, 07:32 PM
Disregard my last post. I found an old TV antenna. It's 3.5 feet long. My dad and I were able to install it. It can go the lenth of my kitchen (20ft.) with ease. My ZZ's new name: X-Country! Thanks guys!
Old 11-24-2002, 07:51 PM
Stridex's Avatar
Chunk
LOL...Damn you're going to poke an eye out with that
Glad we could help. This board is the best place for mod help. What I know I learned right here.
imaginary friend.
Old 11-24-2002, 08:32 PM
ejaf ejaf is offline
3 1/2 Feet Long!!!
Awesome! Where do you live? I could probably meet your car on the corner with mine an do a couple of drags down Broadway
Next step...Directional antenna signal (anybody want to rent some space?).
P.S. This forum ROCKS!!!
Old 11-25-2002, 02:49 PM
Ya, but the sad thing is that I can't go past 30 feet. However, I had to test it on carpet and with metal chairs in the way! But, that's an OBVIOUS improvement over the 10 feet I was getting before! (It might go further in the open and on better a surface too!)
4-band controller + reception Duo64 Bit Char-G Parts and Hop-Ups 18 02-10-2003 01:47 AM
reception problems -v2oracle- Bit Char-G / MicroSizers 19 01-31-2003 10:00 AM
Best Antenna Idea For Reception mini rc man Bit Char-G Mods and Projects 2 01-24-2003 09:30 PM
