Old 09-26-2002, 11:36 PM
JojoPB
motor and gear problems...
hI i'm nEw here... but can sum one tell me how to clean a motor... my tomy 2.6 motors likes to jerk a bit(without gears)... is it cuz its dirty... or is it just my motor suks ah... and my gear on my axle is barely touching the other gear... when i reverse is gets locked up... and sumtimes it doesnt touch at all(when runnin)... can sumone help me??
Old 09-27-2002, 01:31 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
whats your motor speed?
what gears are u using?
which cam are u using?
its best to use the black cams...though...if u use the white one, it tends to get stuck like that....i have no idea why
Old 09-27-2002, 08:44 PM
JojoPB
im using a 2.6 tomy motor... special ED skyline... 8.25.1 gears (TEAL) cams??
Old 09-27-2002, 09:21 PM
cowfish_29's Avatar
yellow fish forever!
'cams' are pinion gears...i dunno why people call them that. Make sure that all your stuff is snapped in all the way. Also, if your motor is bad, then its pretty much shot. they are so small that there is not much you can do. 2.6 and up dont last as long and tend to die spontaneously. I dunno what to do about your step down and axle gears...thats kinda strange....
Old 09-27-2002, 09:22 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
No your talking about the gearing itself, we want to know if your using the BLACK PINION GEAR which is stuck on the motor. If your using the white pinion i hear it can lock up.
Old 09-28-2002, 04:22 AM
JojoPB
well... i use the black pinion gear(cam)... after runnin my engine for about an hour(no gears/NiHM moD) the studdering stoped... but the real problem is that the axel gear tends to not touch the other gear sumtimes... seems like i haved pulled the rear axle out a bit to much and when it locks in place its kinda loose... u think a new gear set would do the trick??
Old 09-28-2002, 11:09 AM
Namuna's Avatar
Namuna Namuna is offline
Hmmmm, NiMH Mod...Then the Motor starts to stutter?
I'd wager your problem ISN'T the motor, but rather a loose or pinched wire going to the motor.
As far as the Gearing, unless you're made other mods...The Axle gear SHOULD make a solid connection to the Idler Gear. Here's a Diagram, just so we're all talking about the same thing (http://tinyrc.com/gallery/Technical/aac)
Does the rear axle have a lot 'play' side-to-side? If so, that's your problem.
Old 09-28-2002, 12:03 PM
mr0072003 mr0072003 is offline
DUDE...i have been having the same problem with my 35mhz car.....I tried everything....antenna mods on car and controller......and then checking to see of the wires inside the PCB board were touching..they wernt...but it was a simple thing that fixed my most annoying problem..stutturing.......i think its caused by the motor and its postion........I moved the motor around and then even changed it....and used some newere gears and now its gone....try this out and tell me what happens
Old 09-28-2002, 01:23 PM
JojoPB
my motor isnt stuttering no more... after runnin it with no gears for an hour... well i have to other gear sets and motors... this is my first car... and probly my last in a while...(15 year olds dont get income)... but i would like to knoe why my axle gear doesnt touch the idle gear sometimes... u think buying a zipzap gears would help??
Old 09-28-2002, 01:59 PM
Something else I noticed yesterday......it seems that some OEM bullet axels are a bit longer than the BITS.....and guess what it causes the gears not to touch if used...any1 else seen this.
Old 09-28-2002, 11:07 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
dont worry
i had the same problem on my first bit due to "OH NO HAIR IN TEH AXLE IM GOING TO TAKE OFF THE AXLE AND CELAN IT" well i did it too much and the notch got worn down axle didnt stay in there it wanted to slip out so i suggest not to take off the back axle much getting a zip zap gear set wont help becusae its not hte gears problem its the chassis's itself
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-29-2002, 02:50 AM
JojoPB
so theres no solution??
Old 11-14-2002, 07:39 PM
RebellionInc's Avatar
RebellionInc RebellionInc is offline
Jetdi Knights
Help!
hello this might not be the right thread but i needed some help kinda fast. i just bought a 3.0 and 150mah battery. the battery work find but the motor kind of chuckles along. i put it in my zz and it wont really move. if anone can help me please lemme kno..
Thanx.......
SPeEdiNG TiCkeTs SuCk
May ThE ForCe Be Wit Ya
Old 02-14-2003, 10:52 AM
Sid Sid is offline
same problem..
I have the same problem..loose axel, so loose idle gear..so very slowwww 1.0 motor..almost crawls..gets locked sometimes in forward...goes like fast slow fast slow..but in backwards it goes normally..anyways to tighten an idle gear? damnit my bit is brand spanking new..like 2 days old..im starting to lose trust in this hobby
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
Old 02-15-2003, 09:48 AM
NOiSeMAKeR96 NOiSeMAKeR96 is offline
sMalL kICks A$s!!
Send a message via AIM to NOiSeMAKeR96 Send a message via Yahoo to NOiSeMAKeR96
ur gears messed up ,same wit me all i did was take off the axle and gave it a little anlinament (BALENCED IT) my gears got jammed because my damn axle was bent and wobbling
