Old 10-30-2002, 08:16 AM
MICROMAZDA MICROMAZDA is offline
Send a message via Yahoo to MICROMAZDA
Hah...thats the same look i had on my lil mazda. I just used the red axle from my bit with the red gear and red motor from Zip. Works fine
Old 10-30-2002, 08:17 AM
DraKhen99 DraKhen99 is offline
Send a message via AIM to DraKhen99
Ah... I have gotten the same results as everyone else around here!
A couple of weeks ago I tried the combination of Red ZZ Motor/Gear/Axle on my MS and it wasn't as fast as my ZZ with the same drivetrain, so I went back to stock on the MS. I will be getting a 2.2 and a 2.6 motor soon, as well as 3 new bits, and I will try some different combos on them :c)
Maybe I should order a 3.0, 3.2, and a 3.8 and do some major comparisons?
-DraKhen99
See my collection of Micro R/Cs:
Old 10-30-2002, 09:29 AM
AudiTF's Avatar
AudiTF AudiTF is offline
Evo VII
Send a message via AIM to AudiTF
Go
if you like black rims do what i did
________
PORN MOVIES
Old 10-30-2002, 02:12 PM
dok's Avatar
dok dok is offline
Send a message via AIM to dok
I don't really like the look, I just want them to match
~dok
Black RX7
Old 10-30-2002, 09:55 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
you can always make your front wheels black and put some other hub cap in the front. That's what i did to my MS. I'll be putting some ZZ wheels in the front soon, so then i don't have to worry about different wheel designs. I also noticed that after about 1 minute of running with the red ZZ motor it seams to wear out it's quickness. Well atleast it is better than the 2.2 motor.
here's a pic of my car
Old 10-30-2002, 10:19 PM
natedogg4674's Avatar
natedogg4674 natedogg4674 is offline
Ill choke slam you!!
i tried the zip front wheels on my zip but it didnt worktoo well, by the time i had modded the chassis enough so the tires didnt rub i had taken apart the front end so many times it didnt steer right, so i just transferred the pcb into the zip, and away i went!! PICS OF MY GARAGE COMING SOON!!
Flamin Dynamite Rocket Racer(7.2)
Honda Epoch Indoor racer 1/43(4 cell)
Auldey Tin Racer 1/32(on the way)
1/10th Traxxas Rustler(Elec)
MS Mitsubishi Lancer
MS Blue WRX
Custom spider mobile bit
orange ff zip w/ bit pcb(2 cell)
green ff zip w/shen pcb(3 cell!!)
2 Shen Qi Wei knockoffs
Walgreens Knock off Celica
Old 10-30-2002, 11:14 PM
mustangfreak mustangfreak is offline
Originally posted by dok
thanks, i didn't know that, i thought it would f things up if i used the red gear with the orange axle, thanks again.
ive got a RX7 MS and ive got my ZZ red motor and gears in and im using the MS orange axel and i have no porblems
Old 10-30-2002, 11:20 PM
SPEED's Avatar
SPEED IS GOOD
a good way to prevent rubbing when using ZZ wheels in the front is to use the Bit knuckles instead. That will make enough room for clearence.
Old 10-31-2002, 12:18 PM
dok's Avatar
dok dok is offline
Orange Gears seam to go slower for me than the red ZZ gears. Not sure why...
~dok
Black RX7
Old 10-31-2002, 02:32 PM
Ok, I'm confused. Can someone please point out the "knuckles" to me??? What part are they on the wheels?
Thanks!
-DraKhen99
Old 10-31-2002, 07:28 PM
SPEED's Avatar
SPEED IS GOOD
the white part the rim is pinned to with the metal pin......
Old 10-31-2002, 08:22 PM
VDOGG VDOGG is offline
OOPS!! Clicked the button twice
Old 10-31-2002, 08:25 PM
Dok, the orange ms gears are the "middle" set, same as the green zz gears, the red gears are the high speed set, thats why the orange seems slower. BTW, what part of West V. are you from? I am from Huntington but live in Mississippi now.
-Vince
Old 10-31-2002, 08:30 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
I am running Zips and Bits. Motors that make Zips move make Bits scream. Zips weigh more.
Smaller models, more control
Old 10-31-2002, 09:07 PM
SPEED's Avatar
SPEED IS GOOD
not to mention that the Bit PCB is pumping more energy to the motor giving it more power...
ZipZap SE question maculosa ZipZaps SE 2 11-02-2004 11:02 PM
Getting a Microsizer... have 1 question Maxxcrazy Bit Char-G / MicroSizers 6 06-03-2003 03:07 PM
lxx & microsizer motor question Blamminator Bit Char-G / MicroSizers 1 02-13-2003 11:57 AM
zipzap or microsizer? what to get ? Takevin ZipZaps 27 10-17-2002 09:15 AM
Purchased 4 knock offs, 1 Microsizer on 5 freqs / results. AceQ Bit Char-G / MicroSizers 1 10-14-2002 11:49 PM
