I was wondering if you can mod a microsizer to be as fast as a boosted bit(Same motor and bat). If it can't be done, then I have a question about the boosted bit. If I buy the booster kit($20)and the 4-channel controller($12), do I need something else also? Thank You for any help, Mike.
Can you mod a Microsizer to be as fast as the Boosted Bit(same motor, bat and gears)? If it can't be done then which booster kit should I get(fastest chassis)? Thanks again, Mike.
I think a reg bit can be as fast for track racing but as far as drag racing booster cars are faster. My boost car with 3.8 has some good take off and serious speed. My reg bit has slow take and seems to be similar top speed but not sure I do not have the room to check. I feel they are still pulling at ten feet.
Fairlady Z kit is sweet!!!!! The four body boost kit looks tight.
I heard that the old boost set's are slower not sure never seen one to compair. Someone set the record straight if you know.
