Originally Posted by nitrojunkie
There are several places to look.
1)Have the tx steering settings been changed?They are adjustable independently side to side.This is done by turning the steering wheel to the side that turns less and giving trim inputs in the same direction,this increases the turn angle.
I did try to do this, but i need to decrease the steering angle to much in order to solve the problem. But with that angle I cannot make a proper turn. He can take the left turn at the maximum angle, so it should be able to do (more or less) the same in the other direction.
2)Clean the car good.Make sure there are no fibers wrapped around the front spindles.Also go on and check the diff for the same and re lube and reassemble.
This was the first thing that I did, but the problem remains after cleaning every possible part.
3) Check the steering for smooth operation make sure it is not sticking on one side while upside down laying on a table.If it sticks this is a sign of a broken steering gear and will have to be replaced.If this is the case you will have to tear the car down to a bare chassis basically.It will take a little bit of time and is somewhat of an aggrevation but once you do this you will know your Dnano intimately and there will be nothing you can't do to it.Just take your time and pay close attention to what goes where and put it back in the same place it was.
Steering is still very smooth, but I will check this again in detail.
The video you posted the link to.That problem could be caused by tire wear from normally running in the other direction.We run on carpet and a road course so this is a rarely seen problem for us.
This was one of the things that I was thinking about. But after switching the tires from left to right, the problem still stays in the right turn... I would assume that it would reverse the problem. Anyways, I'll replace them with PN racing tires asap.
