Old 10-23-2006, 10:59 AM
hackerbl2003 hackerbl2003 is offline
Send a message via AIM to hackerbl2003 Send a message via Yahoo to hackerbl2003
Lithium Battery Montior
Who here can help me with this schematic?
Old 10-23-2006, 01:28 PM
Jazz32
What help do you need? Your part numbers are there and is straight forward. A simple "help" will never get a response. You need to be as detailed as possible.
Old 10-23-2006, 01:56 PM
Just with puting it together.
Old 10-25-2006, 01:16 AM
frizzen frizzen is offline
Tool User
You've got part numbers, a diode, and the traces are all straight forward. just looks like you need to find those parts, whatever type connector you want to use to attach it, a board, and solder it up.
You need to be more specific on how you want help.
Old 10-25-2006, 09:07 AM
help with finding the parts a bord and how to put it together.
Old 11-25-2006, 06:43 PM
PureGrain PureGrain is offline
I am not a master in this type of stuff but let me see if I cna help you out.
Here is a link I found to match te type of "Supervisor" you need. This is the part that does the work. LM810M3-3.08
http://www.national.com/pf/LM/LM810.html
Next you will need this part: Which a google search reveals it is a red LED. L517URD-F
Seems to be fairly simple up front.
From the photo you provided you would wire it up like so.
  • The # 3 tab on the supervisor is wired to the positive side of the battery terminal.
  • The # 1 tab is wired to the Ground
  • The #2 tab is then wired to the + side of the LED and the - side is then wired to the ground side of the battery.
Hope this helps.
Overview On Lithium Ion Batteries moebrown20 XMODS Mods and Projects 19 05-02-2005 09:00 PM
Temp 7.2 battery mod DRRfanatic425 Dynamite Rocket Racer Parts and Hop-Ups 1 08-09-2003 10:47 PM
Battery Basics 101 Namuna Bit Char-G / MicroSizers 35 06-29-2003 09:17 PM
I got a 3v lithium battery for my bit Ovgron Bit Char-G Mods and Projects 4 12-14-2002 10:20 AM
How long will a 3V Lithium Camera Battery Last ??? shred Bit Char-G / MicroSizers 0 10-18-2002 02:41 PM
