Old 08-01-2006, 12:26 PM
bengali548's Avatar
bengali548 bengali548 is offline
(insert something funny)
liths
okay i plan on getting liths but i have a bunch of questions
1) could i use this charger
http://cgi.ebay.com/Ultrafire-Charge...QQcmdZViewItem
with theese cells
http://cgi.ebay.com/Xmod-Lithium-Ion...QQcmdZViewItem
2) does anyone know where i can get cheap liths and a cheap charger (i dont wanna break the bank for liths i spent nearly 200 on my xmod already lol)
3) for speed if i have 6 cells the weight will give it better traction and turning but with liths if i turn will it just roll over.
4) would a aaa battery holder work for the liths i showed above i know the liths have no nipple (nipple hehehehe) and if not do you know where i could buy some and for how much
Old 08-01-2006, 12:39 PM
bengali548's Avatar
http://www.batteryspace.com/index.as...OD&ProdID=2598
i like those batteries but does anyone know where i can pick up a lith charger for 13 dollars cad or lower
Old 08-01-2006, 12:40 PM
Rez Rez is offline
1) Think I answered that one in another thread.
2) Battery Space
3) You have more weight, but a more important factor is, where is that weight? LiIons let you sling that weight low for a good center of gravity. You shouldn't be rolling.
4) If they're AAA sized I suppose they'll fit a AAA holder, but honestly I've never seen anyone do this. Most people solder wires to them and plug the wires.
I really wouldn't skimp on the charger. Save up the money and get yourself a decent lithium charger. You're already making an investment, protect it, and yourself. LiIon batteries can get pissed off if you charge them wrong. And by pissed off I mean on fire.
Rez
a7i20ci7y
Seven Cities RC
Old 08-01-2006, 12:43 PM
bengali548's Avatar
WUTCHU TALKIN BOUT WILLIS
if i do that how am i supposed to charge the batts
actually i saw some chargers on ebay where theres a dean plug sticking out how can i make a charger like that. and how much would it cost me
Old 08-01-2006, 12:45 PM
Rez Rez is offline
You unplug the batteries from the car and plug them into the charger. It's the sameway Atomic Mods guy does his:
http://www.atomicmods.com/ProductInf...roductid=11015
Rez
a7i20ci7y
Seven Cities RC
Old 08-01-2006, 12:47 PM
bengali548's Avatar
i know but where can i get one one of those chargers the one with the dean plug sticking out
Old 08-01-2006, 12:48 PM
Rez Rez is offline
Make one
Rez
a7i20ci7y
Seven Cities RC
Old 08-01-2006, 12:51 PM
bengali548's Avatar
ive never even seen a charger so is there a tut to do this or do you know what wire i have to cut or can u explaion it breifly
Old 08-01-2006, 12:55 PM
bengali548's Avatar
for the page you sent me with the connectors should i just cut of one of the heads
http://www.batteryspace.com/index.as...ProdID=1542and attach that to a dean plug
(focus on the one on the left thats the one i wanted to use to connect to my dean plug
Rez Rez is offline
It really depends on the charger. Some of them you put the batteries in the charger like the auction you linked. Others you hook up to a battery pack. They both have advantages and disadvantages. If you want to be able to switch out the batteries and run the car while another set charges, use the battery boxes and the charger you linked.
Rez
a7i20ci7y
Seven Cities RC
Old 08-01-2006, 05:34 PM
bengali548's Avatar
k when im soldering up the liths same rules apply positive to negative but should i use 18g wire or does ne wire work with it
Old 08-01-2006, 09:38 PM
bengali548's Avatar
http://cgi.ebay.ca/ws/eBayISAPI.dll?...DME:L:RTQ:CA:1
i bought this charger if any of you guys are familiar with it could you tell me if this is a smart charger (it has characteristics of one) and if i could just charge my batteries and go away and not worry about my batts catching on fire or if i have to constantly look after it
just wondering if my batts did catch on fire would it be a HUGE fire or just a little flame that would burn itself out before causing any damage
Old 08-01-2006, 11:26 PM
Rez Rez is offline
I'd just keep an eye on them through the first charge cycle. If they don't get too hot I wouldn't worry much about it.
18g wire should be fine.
Rez
a7i20ci7y
Seven Cities RC
Old 08-01-2006, 11:27 PM
bengali548's Avatar
but do i need it i have spare wires from my old battery kits lying around that i could use
Old 08-01-2006, 11:39 PM
Rez Rez is offline
Depending on what kind of wire they have, I'd just go ahead and put a beefy wire on them. They're going to be pumping out a lot of juice.
Rez
a7i20ci7y
Seven Cities RC
9v??? bengali548 XMODS Parts and Hop-Ups 9 07-31-2006 01:32 AM
3.4 liths powering motor, and 1.5 battery powering servo 15oz XMODS Parts and Hop-Ups 2 04-24-2006 11:35 AM
