i need a new pin for my zip zaps steering system. when i oppened up the steering compartment, i noticed this uhh..spring was bent and it was causing the unequal steering i was recieving because it wasn't aplaying tension when it turned left, and alot of tension to the right, resulting in sharp lefts and wide rights. i've cleaned out the whole inside and everything is put together correctly, i am sure this is my problem. can any point my in the direction of a seller of this peice below?
sry ppl i cant get my image to work, i hope u know what i am talking about, it's a little coil with two stands coming out attcahing to steering trim
