10-08-2002, 11:26 PM
SPEED IS GOOD
My RX-7 with Zip Zap Mods
10-09-2002, 04:25 AM
www.d1gp.com
are u gonna replace the front rims to ZZ rims?
it would match better
10-09-2002, 12:44 PM
i'm not 100% sure about this but there were posts about replacing the front wheels with bigger wheels. and people were talking about how it hurt the handling/turning of bit char-g because of the larger front wheel..
10-09-2002, 04:04 PM
SPEED IS GOOD
i've actually heard that people have great redsults when using the ZZ wheels up front. they say using BIT wheels up front hurt hadnling not the ZZ wheels. and yes i plan to have ZZ wheels up front.
10-20-2002, 10:26 PM
13B REW
hey speed did u take out the zz wheels from axel? or leavin it on? cuz i have a red rx-7 but hate my stock rims.
10-21-2002, 07:54 PM
SPEED IS GOOD
I just left the wheels on the axle, they fit on there perfectly. I have to get another bit char-g though, the POT fell out on mine.
10-21-2002, 09:21 PM
13B REW
do they have zz small wheels 4 the front? or should i just make them big? any pics of how it would look n a rx-7?
10-22-2002, 07:43 PM
SPEED IS GOOD
sorry got no pics, but i've heard that using the ZZ wheels up front help the bit handle better.
10-23-2002, 03:11 AM
13B REW
just got a zz 2day and tried puttin the rear axil 2 my bit, somehow it is loud and dont move as fast. what kind of gear u use?
10-23-2002, 06:53 PM
SPEED IS GOOD
Be sure you use the same colored gears! I used the blue and the red gears with my bit. The red gears seam the best when i tried my bullet motor.
10-23-2002, 06:56 PM
13B REW
y did u say use same color gears and u said red and blue works good? im talkin about puttin the rear axil of the zz 2 the bit. its a stock zz axil which is blue and how come it dont go as fast n my bit? what gear did u use 4 your bit?
10-23-2002, 07:24 PM
SPEED IS GOOD
The red gears work good, and so do the blue gears. Make sure the gear on the axle is the same color as the gear that sits on the little metal poll. If those don't match up you can have bad meshing and that can cause the loud noise. You said you are going to use the blue axle gears. Use the blue "free" gear also (not the gear on the motor, but the gear that transfers the power from the motor to the wheels) Hope that helps you out.
10-23-2002, 08:25 PM
13B REW
hey speed, dhould i get some zz gear set or bit gear set? r they the same? cuz i want the zz1 cuz it cost less i tink. and y is that when i put a clone pink motor that looks like a zz motor in my bit , it goes very fast! like a 3.8, and when i put it n my zz, it goes as slow as my stock zz motor?
10-23-2002, 09:55 PM
SPEED IS GOOD
yes definently get the ZZ gear set!! It's cheaper and the ratio's are exactly the same!! The thing about your clone motor...well i've noticed clone motors are very fast, but i'm not sure what the actual rating on them are. The reason why its so slow in your ZZ (i'm taking a guess here because i have no ZZ) is because the PCB board on the ZZ in not giving as much current to the motor compared to the BIT PCB. YOu have to do the ZZ PCB mod to get it to work right with the clone motor. Not sure how that works, try the ZZ forum. All i know is that it envolves resoldering some wires on the PCB.
10-23-2002, 10:14 PM
13B REW
alright, thx speed  .
