Old 10-20-2002, 06:43 PM
323iT's Avatar
323iT 323iT is offline
Drifters
Who likes to drift their bit char-g? post your set ups here. what kind of method do you use?
my drift car
booster machine
bit racer soft tires(block threads)
red suspension bar with 2 small holes
9.86:1 gears
3.0 motor
silver accord wagon with cf hood
Old 10-20-2002, 06:50 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Update 9/23/2003
On a 2.2 + boost, stock MS Pro chassis + green axle and smooth tile with moderate dust. Accelerate to top speed and hit the turn button and continue to hold. After a circle or two, R/C will kinda slide towards the direction it's turning that has the appearence of drifting.
Old 10-20-2002, 06:56 PM
323iT's Avatar
i have no problem getting the car to drift, but its hard for me to exit the turn.. i usually spin out or end up making donuts
Old 10-20-2002, 07:12 PM
carb0's Avatar
carb0 carb0 is offline
accord master
Send a message via AIM to carb0
stock chassis
2.6
9:86:1 drift axle
hard tires front
plastic tires rear (drifter axle)
silver & white accord body
red suspension #2
lol sounds like someone elses up there >.-
i drift with no prob, my best ones are usually on hard word floor
Old 10-20-2002, 07:22 PM
cowfish_29's Avatar
yellow fish forever!
when i drift this is my setup:
front tires: bit racer hard
back tires: bit racer soft (medium on TheFanMan's track)
softest stablizer bar
blue acceleration gearing
bensu 3.0 (my dirty TOMY 3.0 went and died )
when using hard tires, use slightly softer tires in the back, but hard enough to drift with. Also, if you simultaneously accelerate and turn from a standstill or a near standstill, the car is much more likely to spin, especially with hard tires on smooth surfaces.
wee...i sit on my hardwood floor and figure these things out for hours at a time
-'fish!
Old 10-20-2002, 08:48 PM
323iT's Avatar
-'fish!
is it hard to get your rear end out if you have softer tires in the rear?
Old 10-21-2002, 05:37 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
stock chassis, but slightly shaved in a few areas
3.0
all bit racer medium tires
blue ZZ axles
front ZZ rims
softest red stabalizer
my lightest car bodies
my floor makes it more complicated to drift...so i expriment alot...
still havent gotten it to drift like it want it to....
Old 10-21-2002, 10:15 PM
cowfish_29's Avatar
nope! when you use blue acceleration gears with a fast, powerful motor (bensu clone motors are my fav) the back end slides out nicely, especially on hardwood floors or tabletops. The reason i don't want it to slide too much, is because you just end up doing donuts, and that is annoying.
Old 10-22-2002, 11:54 AM
323iT's Avatar
so would you use blue gears for more accel or teal for more speed?
I prefer more speed going into the corner. easier for me to get the tail out
Old 10-22-2002, 11:02 PM
cowfish_29's Avatar
yeah...for slipperier tracks i bet the teals would be better for coming out of the drift b/c it would have less spinning power to being "donut-ing"
but on rougher stuff unfinished plywood and cement, the orange or blue gears work well... little more drift without having to worry about donuts as much.
also, dust screws this all up...i wipe the floor down sometimes.
Old 10-24-2002, 11:40 AM
lanevo7 lanevo7 is offline
i use the blue gears with a 3.0 motor and have soft bit racer tires in the front and stock tires at the back (no changes to the stab. bar).
i can't get my car to drift at all....
i think these cars a lil too small/ sensitive to do great drifts..i could be wrong..
with my setup i get great turns without flipping or spinning out...(as long as i keep my back tires clean)
note: i do not consider donuts or spin out as drifts...
Old 10-24-2002, 11:57 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
My set-up:
2.6
9.86:1, sometimes 8.25:1
hard tires front
medium tires rear
silver bB (body lowered in the front) or takumi's 86
medium stabilizer bar
drifts around the kitchen chair legs great.
Old 10-24-2002, 01:07 PM
323iT's Avatar
they are very hard to drift. i don't consider donuts drifting either. when i say drifting i mean making a turn and the rear end of the car is slipping through out the whole turn. these cars are very hard to drift cuz the steering are not proportional. but they are driftable. i've seen a japanese clip where the car drifted a lil bit. (no pun intended)
Old 10-24-2002, 03:31 PM
hey, 323iT
i'd love to see that video of that drift...can you post a link to it?
Old 10-24-2002, 04:33 PM
323iT's Avatar
hey, 323iT
sorry but i don't remember where i saw it. it was a year ago
DRIFTERS ... anyone ever seen a Hirobo DRICON kylelucas Other Tiny RCs 5 10-06-2004 08:29 AM
attention XMODS drifters Daazndood XMODS 29 11-27-2003 06:27 PM
Boosters are good drifters! Zephyranthes Bit Char-G / MicroSizers 2 04-02-2003 12:56 AM
