10-12-2004, 09:01 PM
Re: nice
Originally posted by whitenight
who fast does ur Xmod go?
I don't know, I don't test my cars in that way. I put them on the street and give it all I got!(It beats my supra which has a 36t, old Impala motor)
Where do you hook up the leads of the turbo onto the xmod?
Yes it works the same way. As far as I see, both xmods and mini-z's boards are the same(mini-z is more efficent)
11-02-2004, 02:41 PM
yo
i was lookin at that pic of ur car those batteries u have there huge wat r they(like wat type)? , how many volts? and were do u get dem?
visit my site of Xmods its SICK... sign the guestbook if u like it send ur pics and ill put it on for u no problem
11-02-2004, 05:34 PM
Re: yo
Panasonic CGR18650 3.7 Volt 1400-Mah Graphite Lithium-Ion batteries. You can get they from here: http://onlybatteries.com/showitem.asp?ItemID=11142.11
They are too big for stock Xmods, I have mine in a extended (1/24th scale) ford focus.
11-02-2004, 07:04 PM
k
thankz but how do u extened?
11-02-2004, 07:12 PM
Re: k
I just made a plate. Some people use a cd case. If you want, I could build you one. Here's a pic:
11-30-2004, 09:34 AM
Go me...
Good God...you've created a monster...
11-30-2004, 09:54 AM
No, thats not my monster........
I just finished my protype turbo and motor.
With 2 lithium I can reach 82 easy.
And with 3 I don't know............. Did you know that the speed checker maxium is 99. After that it said error.
11-30-2004, 09:58 AM
You should see my next project. Will be finished next week!
12-01-2004, 05:50 PM
3D Racer
How does the mini-z turbo hook up? Is that a MR-02 turbo?
If it ain't broke make it better
12-01-2004, 06:02 PM
No, it's not MR-02 turbo(they have no breaks). I am made my own version (similar to Woah-nelly but larger fets) so I could keep my break-function. I'm pretty much limited to batteries now(need very high MaH).
All of the Mini-Z turbos I have used were installed the same way the instruction describe.
12-02-2004, 11:36 AM
Go me...
Are you in the monster business or something?
How do the turbos work? Are they just really big capacitors?
12-02-2004, 05:20 PM
Banned
hey moebrown what kinda motor are you runin?
12-02-2004, 05:22 PM
The turbo I build works the same way your stock fets' work. I wanted to use it on a track and I needed breaks. (I tried a turbo without breaks on the track, and I melted the solder off of it)
The monster business... lol, no, I just want the fastest Xmod possible. As long as everything fits under the body and its fast, I'm happy. When I'm finished, I will post a picture.
12-02-2004, 05:33 PM
I use several motors:
The stage 4 I use on the track. It tops out at 56-58km.
The Impala I use on a street track (oval or straight-away). The max on that I've seen was 65km but 60 is normal.
This new motor I'm working on Cheetah-X (named after a slot motor that was discontinued) I still get different speeds. One time I get 94 the next I get 86km. I'm looking for 82- 84km on a oval track and mid to high 90's in a drag.
12-03-2004, 11:38 PM
5Zigen
I realized that the Xmod has brakes just like the MR02.
The brake function may burn out the Turbo.
What did you use to counteract this?
(or did you just get a MR02/OL Turbo?)
Try And Sleep Now.
DRIFT my ANTI-rice
