08-18-2004, 08:22 AM
Actual stage of my mini X prototype
Here is the current stage of my prototype:
Carbon Fiber Chassis and upper desk, six 2/3 A cells (1100 mA) longer wheelbase (110 mm) using a mini z 8T pinion on the front (shown in the picture). Alu slotcar rims with foam tires.
Next step: coil spring dampers (micro rs4 alluminium dampers). Steering linkage.
The body will be a lexan 1/24 nissan from truescaleproducts;
08-18-2004, 08:23 AM
another pic
08-18-2004, 08:24 AM
mini z pinion allows a longer wheelbase, necessary for 1/24 body
08-18-2004, 08:25 AM
CF chassis
08-20-2004, 04:40 AM
body
08-20-2004, 03:28 PM
Steering linkage (handling is 200% better and faster!!) and front bumper done.
08-21-2004, 02:54 AM
body paint
08-23-2004, 05:14 AM
Dude, that looks sweet.
Any copies of that chasis available? or plans for it?
you have got Excellent results, good work that man.
Ted
Mini-x: Subaru
6 Cells
Bearings all round
vented bearing can
O/l tyres
08-24-2004, 06:15 AM
Thank you Ted, no copies are available...it is an artigianal production! If you want plans I can give them to you, but you have to cut completely the original car to use this chassis.
08-24-2004, 06:57 AM
Wow, amazing work xemet!
09-03-2004, 03:09 AM
looking great... one hell of an X
||| It does not matter if you win or lose. It only matters if I do. |||
09-28-2004, 07:22 AM
It would be great to get rid of the long shaft motor.
10-01-2004, 06:23 AM
I need that plans.
Can u mail me at wing@cbn.net.id
Thank u verymuch.
10-15-2004, 09:35 AM
to ben1112
I have worked on a procedure to extract the axle from a common rotor and to insert in it the long axle for minix 4wd.
In this way I can virtually use every 130 size motor. Now I'm preparing a 4wd motor with PN 38T rotor, a bearing can, neo magnets and high quality carbon brushes.
I will post results...I'm waiting for the rotor bought on rckenon, I think it should arrive the next week.
See you soon!
11-09-2004, 03:38 AM
this is my car now, with new 38T motor, new novak spy esc and new body.
