08-21-2004, 11:18 AM
Pimpin'em Hoes
Originally posted by sherifx
I'd love to use I micro rs4 motor such as this:
but there is no way to tie the rear down.
sherif
where u find that i need a site with huge motors like that can some people help me
Red metal flake civic project tons of upgrades
08-22-2004, 11:53 AM
Lancer- you can get them at towerhobbies
09-17-2004, 12:00 AM
Hi guys,
I havent been into xmods long and have been hanging out at xmodworld since I have,just found this site. Im glad to see that people over here are trying to get power with the 180s. I have been messing with them myself a little but havent got the results I want yet.
I built a 180 from a colgate tooth brush,trimed the can down so I could fit 130 endcap with carbon brushes and rewound it to 53 raps. It had a little better top end but the torque was not that great . From what im reading here I should go lower with the raps on a 180,didn't know this when I did it.
I think the reason the 180s are not performing is because of the stock magnets. When we take the raps down on these 180s we are killing the torque, we need some stronger mags to bring torque back up substantualy over a 130 and low raps so it will have rps like a 130. Thats what Ive been trying to find ,neo mags for a 180 or even isotropic ferret mags for 180. My thinking is that the colgate 180 has standard ferret mags in it and thet fact that they are longer along with longer armature is what makes it more powerful than 130. when we take raps down we bring power(torque) down closer to a 130 thats why we need mags to balance it back out.
Does anyone here know where to get neodymium mags for 180? Thought about useing four 130 neo mags,two on each side of can with one on each side trimed down so that together they would equal length of 180 mag. Dont know if this would work ,what do some of you think?
On another note, I have a 170 from a panasonic shaver(ES4001) in my car for now. Its a little smaller than a 130 or 180 but the same length as 180. iT Blows the colgate 180 away,it has way more torque but seems to have good rpm. Mine has 8 tooth pinion on it and its still faster than the 180 with 9 tooth pinion plus the170 accelerates way better. sorry post was so long
09-20-2004, 12:53 AM
you're using carbon brushes, 130 style winding, 130 style endbell, and still getting nothing? have you checked that the motor spins freely by itself?
10-09-2004, 06:40 PM
did any body try to put a air plane brushless motor it just wont have rev. in it you'll have to use another controler to
10-31-2004, 05:17 PM
Can't run a brushless systum unless you change all the electronics out...such as the reciver, sevo possibly and then i belive 180 sized burshless motar draws 10 amps or more?!
11-23-2004, 12:38 AM
How can you tell how many amps a motor draws, to see if it will be safe for the stock FETS?
I have 2 motors that I was thinking about trying in my Xmod.
Also, where can I get a pinion puller, or something similar?
11-24-2004, 09:24 AM
Go me...
sherif
Use hose clamps or zip ties to attach it to the chassis.
11-24-2004, 04:07 PM
12-14-2004, 02:50 AM
fast, but not really in the hot 130 league.
and technically speaking it's not really worth $30...
01-27-2005, 08:08 PM
i have a ff-180sh/ph also and also filed down the ends but i rewound it with 26ga wire 30 times. it has nice rpms and torque now and i only have a 2x2 stack of stock fets(i'm too cheap to buy them) my fets don't even get hot
also if you check this forum you'll find this setup only draws .5 amps=
http://www.tinyrc.com/forums/showthr...threadid=16023
do you think it would draw way more current if i took off like 5 winds
i only mentiones this because i know the plasma dash(130) has like 27 winds of 26ga
02-13-2005, 05:50 PM
it will draw more amps, but not nearly as much as the plasma... the 180 can takes more wire per turn, so you'll probaby draw less than 1A with 27 turns.
02-16-2005, 02:07 PM
Another nod here for TO Elite Micro stock. I have an 11t pinion and I raced a car with 2Wd and a RS S2 9T motor and I gave him a car head start and I just smoked him. Race was about 20 ft. Even on 50 ft runs, I kill him.
02-25-2005, 09:55 PM
Originally posted by 00black_civic
Last one
so if i put this one in my stalk skyline it wold work fine?
X-MODS RULE!!! oh yea and evil monkeys will come to kill us ALL!!!
02-25-2005, 09:56 PM
im talking about the last pic of his motors on page two i think
