Old 08-05-2004, 10:54 PM
bitter being bitter being is offline
Question front wheel removal?
Hi,
I was wondering how to take off the wheel from the pin. To me it seems backwards. And it isn't compatable to other ZZ's or Bits..
Burninate.
Old 08-06-2004, 05:15 AM
Bad Company's Avatar
If you perform a search for wheel mod or DUB City wheels you should find a few topics and even some pictures how to change the wheels.
The Zips wheels and Bit wheels are compatable with each other. You can also install many 1/64 diecast wheels.
Old 08-06-2004, 10:43 AM
Oops,
I forgot to say I have an SE. They have a plastic nub that is painted silver instead of the pins stopper at the front part of the wheel. And on the back part of the wheel I think it's the pin's stopper but im not to sure. If I get gutsy enough to pull the pin out could i jsut invert the pin so it faces outwards if the stopper is facing inwards?
Burninate.
Old 08-06-2004, 03:13 PM
No, my bad. I forgot I was looking at the SE forum. It's been a while since I did it, but I pretty much did the same thing as with the Zips, except I pulled the pin out from behind the knuckle, and I either reused that pin or used a regular Zip pin and inserted it thru the wheel into the the outer side of the knuckle.
Old 08-10-2004, 01:10 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Check this thread. I explained one way to remove the front wheels here.
http://www.tinyrc.com/forums/showthr...threadid=19697 Just be gentle with your lil SE.
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
Carpet hairs stuck inside front wheel NTolerance ZipZaps SE 8 01-17-2004 09:15 PM
FWD XMOD!! YES! Front Wheel Drive!! MicroRCracer XMODS Parts and Hop-Ups 60 01-14-2004 03:32 PM
Non front wheel turning or front wheel turning? bvsciguy Digi Q 0 09-13-2003 10:05 AM
Front left wheel binds up, halting operation. BackInBlack Bit Char-G / MicroSizers 5 10-07-2002 05:44 PM
