08-01-2004, 09:45 PM
I can't get dual cell to work with zz
look, i need some help with the dual cellfor a zz. I have two of the little green batteries but there is a piece of plastic blocking the way so i can't fit both of the nimh batteries.
08-02-2004, 01:29 AM
I process, therefore I am
You have to dremel or cut that little bit of plastic out in order to get the batteries in. And you have to flip the PCB over.
08-02-2004, 01:32 AM
i just dual celled my zz and u can take out the plastic blocks with needle nosed plyers,u dont have to flip the pcb over, well i didnt and my zz dual cell worked perfectly with the body on too!
08-04-2004, 12:13 PM
zz dual
i have foung the best dual mod to be the sleeper mod....flip the pcb upside down dremel the box that holds the clip for the charger out (you may want to glue in a piece of plastic from one of the packages with a flap cut out ( i did cant say if its any better with another battery in there anywayz it will cover the hole somewhat and radius of battery will allow you to get the charger clip in there.) and stick in your 2nd battery....or if you want to get crazy stick in a 2.4v 70nimh out of a se in the front and then rip an se battery in half and stick it in the smaller area where the stock 100nim 1.2v was. i also dont recomend dremeling off thepost holding the stock battery in place.
08-04-2004, 12:18 PM
why
just for balance...
