Old 07-10-2004, 10:30 PM
SupraMan017 SupraMan017 is offline
Type-R
Send a message via AIM to SupraMan017
Front Wheel Drive Integra
I just got done mounting a 25th scale Integra Type-R body on my XMOD. I like realism and was trying to make the car front wheel drive but the gears keep slipping off. Then I thought about moving the motor to the front. Has anyone tried this mod? Can anyone give me a few ideas on how to do this?
My XMOD:
Acura Integra Type-R
180 Motor with Drag Pinion
6-Cell Upgrade
FWD
Locked LSD
Hard Springs Front and Back
Soft Slicks in Front
Hard Slicks in Back
Old 07-11-2004, 01:39 AM
lancer11's Avatar
lancer11 lancer11 is offline
Pimpin'em Hoes
Send a message via AIM to lancer11 Send a message via Yahoo to lancer11
just glue the gear to the shaft
Old 07-13-2004, 01:16 PM
SHIFT_DRIFT's Avatar
5Zigen
no dont do that.
just remove the rear diff;
or remove the gears in the rear diff for smoother operation.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 07-18-2004, 11:11 PM
spinitsidewayz!'s Avatar
boro dori style RC
moving the engine to the front would be awesome and would fix weight distribution problems... (fwd xmods like to burn out and understeer like crazy) but theres no room up there... instead of keeping the rear axles in back i put the original front axles and ran a penshaft going to ethier side to keep them from moving around and to keep the gear from slipping. runs pretty ok but with fwd my front end vibrates liek crazy on launches and lsd wont fit
r34 - rwd
r34 - awd
dd4 - fwd
Old 07-22-2004, 04:17 PM
maxvelox03 maxvelox03 is offline
JDM Enthusiast
Send a message via AIM to maxvelox03
Front Mount.
Wow, mounting the motor in the front would be a first . . . and pretty cool too man. I just did the basic FWD conversion to my Si.
J . D . M
Old 07-23-2004, 01:29 AM
boro dori style RC
another advantage is cooling... just cut out ur front bumper and do a hood lift or even a high flow heat sink
r34 - rwd
r34 - awd
dd4 - fwd
Old 07-29-2004, 06:07 PM
Kevmiester's Avatar
Kevmiester Kevmiester is offline
Ferrari rox and so do i
what do you mean by a high flow heat sink? and also how did the gears slip off when you drove it? I did fwd to my skyline temporarily(sp?) and it worked fine the whole time.
Skyline with RS graphics
All RS upgrdes
4.5 Stiff/front Medium/back
9 tooth drag motor
GTR Xtreme kit from cXp
Custom internal intenna
Custom lights with fogs and tailpipe
Mono-shock in rear
Red Ferrari 360 modena body in the works
Old 07-29-2004, 10:43 PM
Type-R
For the integra body to fit and work good i had to extend the chassis. Therefore the axle didnt hold the gear on.
My XMOD:
6-Cell Upgrade
FWD
Locked LSD
Hard Slicks in Back
Old 07-31-2004, 09:43 PM
boro dori style RC
for the heatsink if you had the engine in the front you could just cut out a nice grill for air to flow through and have some aluminum fin heatsink set up attached to the motor.. think of the cooling possibilities
the gears sliped off because i didnt put the rear axles/cups in place so the spur gear or w/e theyre called on xmods.. it kept falling out...
r34 - rwd
r34 - awd
dd4 - fwd
Old 08-05-2004, 12:51 AM
hotrod29728's Avatar
I must admit even though I hate the AWD kit for drifting and other such things its great for conversions and I do believe that there is a great possibity that someone will eventually do this mod. BTW I have AWD set up in my Supra...
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Can you make an XMOD FWD?? (FRONT WHEEL DRIVE) jamiekulhanek XMODS 3 06-04-2004 12:24 PM
Xmods _FRONT_ Wheel Drive Daedalusleto XMODS Mods and Projects 7 05-16-2004 09:29 AM
should i do Front Wheel Drive mod? suprafreak33 XMODS Parts and Hop-Ups 12 02-03-2004 09:36 AM
FWD XMOD!! YES! Front Wheel Drive!! MicroRCracer XMODS Parts and Hop-Ups 60 01-14-2004 03:32 PM
