06-18-2004, 11:45 PM
epoch pcb
i am going to be putting a li-poly batterie in my epoch as many of you guys know that already. but i was thinking about runnjing a 2 cell li po. but i need to know how much volts the epoch pcb can handle. since a 1 cell li po is 3.7 v and a 2 cell is 7.4. but ive never seen anyone witha 6 cell epoch. a 5 but not a 6. i think tis mainly b/c 6 wouldnt fit. but a 2 cell li po would be .2v more power than a 6. so why dont people do this. i know i wont be able to keep my epoch stop. i geuss i could find out how much the pcb can hande since the pcbs only cost $9.
06-19-2004, 12:14 AM
im rick james bytch
dont exceed more then 6.0 volts.....5 normal cells......anything more will fry it unless you do some fet upgrades....when i tried the 6 cell it got warm real fast.....theres plenty of room .....theres a 7 cell on the forum somewhere but they upgraded the fets.
06-19-2004, 10:17 AM
since everone is telling me to upgrade fetts(many diffrent forums) where can i get them. and wich ones do i buy. i do not know witch to get. i do solder good though. i do know what the fetts look like. but they all are diffrent so i would not know what ones to get. i will lok around for that fett upgrade thread you were talking about.
Thanks,
Bryan
06-19-2004, 10:39 AM
ok i was thinking about the fetts. and well i dont have my epoch yet and was wondering if the stearing has the same kind of fetts as the motor. if they do then that means i wont have to buy 3 epoch pcbs.
06-19-2004, 01:25 PM
im rick james bytch
the steering is different type
06-21-2004, 03:54 PM
ok thanks. that mean i will have to buy like 3 pcbs to do a fett job. thanks.
08-05-2004, 01:41 AM
I don't know 2G2SILVERSTRAT having the same spec1/spec2 pcb as mine, but from what i discovered yet both use the same h-bridge IC (LB1638M) in driving the motor. The datasheet of this IC said that it can withstand max 1A current & 10.5V voltage, but it only allowed 440mW power dissipation......... hope these information may help you~~~
(But for other components on the pcb, I don't know whether they can support such a high voltage/current or not)
