10-18-2002, 10:14 AM
Will the Bit Char-G 3.8 fit in my ZipZap?
I guess the title says it all. What's the quickest motor I can get for my miniStang?
10-18-2002, 11:13 AM
1. Will it fit? YES
2. Will it work? YES/NO.
You will need to mod your car to make the 3.8 work. Either the reverse or dual battery mods should get the 3.8 moving. You could also do a PCB switch from a Minisizer.
10-18-2002, 11:31 AM
Retarded Stunt Driver
i have a second battery and a 26,000 motor ready to get installed once i get access to some soldering equipment. so hopefully monday ill let you guys know how easy it is.
10-18-2002, 01:59 PM
It's super useless!
Originally posted by Barry
....a Minisizer.
MICROsizer  .
I think I heard that the ZZ don't have enough juice going to the motors in order for it to run faster motors at Bit Char performance.
10-18-2002, 03:18 PM
1. Will it fit? YES
What's the easiest/cheapest way to get that 38K RPM motor to work? Sorry; I'm VERY new to this!
10-18-2002, 03:22 PM
more power!!
they are all cheap most dont cost more than five bucks it just depends on your skills and time search the forum you will find numerous post on this look for dual mods and pcb mods
10-18-2002, 07:01 PM
do thew no reverse mod...you wont have reverse but if your good enough you wont need it
10-18-2002, 10:56 PM
The online drunk
How do you do the reverse mod(I've done a search)? And, if I do the dual battery mod, do I wire the second battery in series(+to-)or paralel(-to-/+to+)? Thanks for any help, Mike.
10-18-2002, 11:40 PM
10-18-2002, 11:52 PM
The online drunk
Can I run the 2.6/3.0/3.8 motors with the no/rev mod? If so I'm going to order the motors and do the mod tomorrow.
10-19-2002, 12:00 AM
That MOD should get you the voltage needed to push the higher motors with no problem. The results so far have been good.
10-19-2002, 12:08 AM
The online drunk
Thank You for your help. I only have the "turbo" motor now, but I'll order the bigger motors and then, maybe, do the dual battery mod.
10-19-2002, 01:09 AM
I am running red motor and gears with great results after the no reverse mod. It is easy to undo the mod so I would give it a shot first before performing the others. Hell it might be fast enough without the extra cell (ok I don't see that happening)
Glad I could help.
Russ
