04-12-2004, 09:15 PM
DOOM DOOM DOOM DOOOOOOM!!
1970 fast & furious charger. need help
i just bought a amt/ertl charger from wally world and i wanted to fit the body onto the xmod chassy. now im only 16 and i dont really hav ne experience with this, so plz bear with me.
can ne one tell me:
where r the best places to cut.
and
what materials i need to do this mod.
any help is appreciated. thnx
04-13-2004, 12:04 AM
you want to fit the charger with the body and chasiss?
My Skyline:
6-cell
stage 2 yellow
tire upgrade
ni-mh batteries
bodykit
command logic lights
alluminum cups
AWD kit
Coming soon:
2x3 fet stack
30t 130 motor with neos and a vented bb can
Li-ion cells
carbonfiber chassis
carbonfiber driveshaft
04-13-2004, 08:30 AM
no. i want to use the shell of the charger and put it over the xmod chassy. if i wasnt using the right terms, let me kno.
04-13-2004, 02:53 PM
can you give me a link of what it looks like then we might be getting somewhere
My Skyline:
6-cell
stage 2 yellow
tire upgrade
ni-mh batteries
bodykit
alluminum cups
AWD kit
Coming soon:
2x3 fet stack
Li-ion cells
carbonfiber chassis
04-13-2004, 04:00 PM
04-13-2004, 06:43 PM
I don't know how to mount it on the chasiss but some where in the xmod fourm someone did it
My Skyline:
6-cell
stage 2 yellow
tire upgrade
ni-mh batteries
bodykit
alluminum cups
AWD kit
Coming soon:
2x3 fet stack
Li-ion cells
carbonfiber chassis
04-13-2004, 07:36 PM
Do you getto dremel?
have you tryed to fit the body with out cutting? if it does interfere where does it interfere and how bad is it. dont worry about only being 16 im only 13 it just takes screwing up and learning what to do or not do . the materials you will need are a knife, a ruler, various files and sanding tools. i like to use a pair of side cutters for big cuts that dont have to be perfect
P.S. you have carbonfiber chassis under comming soon in your signature twice
04-13-2004, 07:56 PM
yea i hav tried fittin it and i need to find a way to cut out 2mm of the body without ruining it. i thought about cutting 1mm from each wheel well but i dont kno how it will look
04-14-2004, 04:55 PM
no prob. and thanx for helpin. i wuz just about to start cuttin
04-15-2004, 04:51 PM
Awesum. Thanx a million.im gonna go 2 hobby town sat. and pik up sum stuff so i can start. BTW duz neone know which 1:24 dubcity cars come w/ spinners?
04-16-2004, 11:40 PM
i think ill die early ..
NOW WAIT UP HERE!!!! AMT/ERTL???
If you got an AMT/ERTL model it should be very easy to mount it on an X-MOD body if its soft plastic
thats all i have to say!
04-19-2004, 03:17 PM
hes got a point. just because one amt/ertl 1:25 scale car might have fit on an xmod chassi w/out a problem, doent mean that all cars of the same scale will do the same.
04-19-2004, 09:05 PM
no no no no no no
u got it alllllllllllllllllllllllllllllll wrong
you dont cut the body u extend the chassis
u make plastic tabs to lengthen the chassis and put them in between the back and front peices of chassis
(Then u extend the drive shaft IF U WANT AWD TO WORK otherwise just take out the driveshaft)
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
04-27-2004, 10:23 PM
man, mounting a die cast body on an xmod would weigh it down a LOT....but if your just doing it for show then good luck.
-yellow skyline
-wild body kit w/ stock spoiler
-180 sized mega-x motor by NML
-2x2 stack FET upgrade
-stiff springs in rear, medium springs in front
-3.0 toe-in
-rim upgrade
-soft tread tires
-vinyl and decal upgrade
-6th cell upgrade
-command logic lights
-rs metal ball bearings
-alloy cup joints in the front
04-28-2004, 04:13 PM
wtf r u talkin about????????? its not die cast. its plastic
