Go Back   TinyRC.com > 1/64 and Smaller > ZipZaps, ZipZaps SE > ZipZaps Mods and Projects
Old 03-31-2004, 11:44 PM
FordTrucktexan FordTrucktexan is offline
Dual cell problems
Hey guys.. I'm having probs... I managed to screw up one ZZ by accidently unsoldering the steering connections, those who can't micro solder feel my pain...
Anyway so I had this extra battery now, I bought another ZZ and soldered a wire connecting the + tip of one battery to the - end of the other, taped em' up and used the ZZ charger to figure out which wire was hot and which was -, and soldered them to the stock battery terminals.
At first the charger would turn a faint greenish orange and nothing would happen. I switched the terminals and now the led turns red as if it's charging and the car runs while on the charger but that's it, it won't run under it's own battery power. What's going on?
Oh and it has the ZZ 28k motor with performace gears...
ZZ '03 black Firebird and '03 Jeep
Old 04-01-2004, 03:10 AM
clxfiles clxfiles is offline
It's kinda hard to picture what's going on but if the car goes while on the charger, then it is running off the chargers power. When you take it off, it tries to run off the batteries power but since it can't that would point me in the direction of troubleshooting the battery connections. The two problems I've seen like that was either a bad connection between batteries or a short somewhere in the connections.
Old 04-02-2004, 11:20 AM
Sawblade's Avatar
Sawblade Sawblade is offline
Wheeeelie!
The stock charger doesn't have enough power to charge a dual celled ZZ. You'll need to connect a couple of C or D batteries together in series and connect them to your car to be able to charge it up.
Also, you could a 3v power supply so you don't have to use batteries.
-=Sawblade=-
Wheelie poppin' Red ZZ F-150 - Rear soft microsizers tires, Front hard tires, beer keg tri-cell mod, anti-roll bars, wheelie bars, 1/8" body drop, rare earth steering magnet, dual return springs, steering stabilizer bar and spring suspension, 28K Orange ZZ motor, Red 12:1 gears, 22ga power wires, heatshrinked antenna wire, .
Old 04-02-2004, 08:31 PM
spamman spamman is offline
Send a message via ICQ to spamman
Sawblade is right... you need a different charger if you're dual cell'n. I'm using a variable AC adaptor... it's much more consistant than batteries.
Old 04-04-2004, 10:01 AM
JAC4412 JAC4412 is offline
Micro rc fanatic
Send a message via AIM to JAC4412
You need to make what is call a stand alone charger. Here is a good tutorial (by me) I'll get some pics for you. http://ripper7racing.com/forums/inde...st=0&#entry916
Evil RC
dual cell problems bitter being Bit Char-G / MicroSizers 1 07-27-2004 04:06 AM
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 08:42 PM
Dual Cell problems Zephyranthes Bit Char-G / MicroSizers 0 03-31-2003 12:08 AM
Dual Cell mod problems Zephyranthes Bit Char-G Mods and Projects 17 02-03-2003 04:30 PM
