03-14-2004, 01:38 PM
tadiran lithium
i saw these in my local rs they are 3.6 volt non rec hargable batts.
blue civic + v1 power board + miniz workshop 35 turn+ lithiums =one fast car
03-14-2004, 02:56 PM
boro dori style RC
wow 3.6 volts... 4 is like 14.4v. nice find but i think 14 volts is a bit much for stock fets. those would be great for highspeed races with a fet modded car. smoke 6cells and you wouldnt have the weight problem.
too bad they arnt rechargable.
r34 - rwd
r34 - awd
dd4 - fwd
03-14-2004, 03:18 PM
Probably eight bucks a pop, too.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
03-14-2004, 03:25 PM
try 11.49 for ONE!
03-14-2004, 03:30 PM
boro dori style RC
lol expensive... like gas -___-
hey joey i love ur avatar. cleeean rx7
j/w but what did you use for wheel spacers?
r34 - rwd
r34 - awd
dd4 - fwd
03-14-2004, 04:05 PM
A little bag of varying RS washers.
There was a thread on it a while back with the product number.
Mazda Savanna RX-7
03-14-2004, 05:53 PM
joey did you actually get the spacers to stay on the front wheels because i bought those washers but when i tighten the nuts on the wheels there either too loose or too tight.
03-14-2004, 06:54 PM
I don't remember where, but someone I was chatting with found those for $2.50 per cell. So look around. Don't buy those Tadiran Lithiums from Radio Shack. They want $10.99 a pop where I live. You can almost get one of Rob's li-ion rechargeables for that much. www.atomicmods.com
Sorry, no vids for now.
03-14-2004, 08:04 PM
Yeah, but it did take a little while. I originally used three of the smallest washers in the bag for the rear and two for the front, but I ended up having to use two (per wheel) for the rear and one each for the front. You just have to tighten the nuts enough that there's a little pressure on the washers, and I even resorted to using the spare nuts I had because they weren't broken in, and thusly had more thread resistance.
They're a tricky proposition regardless.
Mazda Savanna RX-7
03-14-2004, 10:17 PM
i dont really understand because the smallest washers dont even fit on the axels they only fit on the screw part of the part where you screw the nut on.
03-17-2004, 10:50 PM
pls keep this on topic thx
