Old 02-13-2004, 02:54 PM
cyborgzero cyborgzero is offline
Zzse Fet Mod Climb Video!!!
www.cyborgzero.com/video/cztfetmodzzse.mpg
There is proof of the power of the CZT fet mod I do.
Note the only thing keeping that sucker from climbing a wall is merely traction, and that is with the red turbo gears and the NEX purple motor.
I took the body off so that no one would accuse me of having an extra cell in there or something.
The file is about 2megs, so be aware that if you have dialup it might not be too much fun lol.
It starts out at around 25 degrees, then I tilt it to nearly 45 degrees and it just keeps them wheels spinning! It wants to continue to climb, but there just isn't enough traction.
Rob
Old 02-13-2004, 03:42 PM
charliebrown's Avatar
Cool! Let us see how it is on a flat surface, with no resistance, let us see how the speed is with that thing. Also, for traction, use the all season tires and make sure they are REALLY clean (I dunk them in hot water and leave them in there for about 20 seconds, then take em out and clean em dry.) That way, you're bound to have traction.
Chuckster...
Old 02-13-2004, 04:23 PM
Okay, here
Sorry for all the drifting btw..
www.cyborgzero.com/video/cztzzsedrift.mpg
Have fun!
Mind you, I took your idea of using the all-weathers and wow, I can actually keep it somewhat under control now lol!
Before it would go into terminal donuts and the only way out was to come off the gas almost completely..
Rob
Old 02-13-2004, 05:26 PM
Woah......that's just....insane....
And I wouldn't call that drifting, maybe powersliding. Drifting is where you are sliding the car sideways, basically. Try to get up to a FAST speed, then let off the throttle and turn sharply, when you start to slide then quickly turn the other way to prevent spinning out. YOu'll have to do it quickly, knowing how fast these cars react.
Chuckster...
Old 02-13-2004, 06:20 PM
Yah, there is one or 2 instances where I catch it and you can see the rear end swing out and I countersteer it.. Its pretty tough though, i mean, the whopping 20grams tends to shift its weight rather quickly lol!
Rob
Old 02-13-2004, 07:27 PM
nitrousmaniac nitrousmaniac is offline
D1 Grand Prix
i would call it......... uncontrollable steering?
hi, i am here
Old 02-13-2004, 07:36 PM
Well I changed the steering motor so its now WAY more controllable, so I will post another vid when I get the chance.
And I am gonna put some wider wheels on it to get some control back lol..
Rob
Epoch Spec 2 FET mod IS possible micro_Amps Epoch RC1/43 Parts and Hop-Ups 4 01-25-2005 12:45 AM
does anyone do SE fet mod in US? gtr2112 ZipZaps SE 2 11-14-2004 11:49 AM
Need Help With FET Mod Speedking221 ZipZaps Mods and Projects 3 08-11-2004 08:49 PM
Anyone consider selling an external FET mod (regulator mod)? RC 2NR XMODS Mods and Projects 13 02-09-2004 03:46 PM
"Quick" fet modded SE video bdebde ZipZaps SE 18 12-27-2003 06:15 PM
