Old 02-13-2004, 12:21 AM
newbitowner's Avatar
what is the most effective way of clearing the lights?
automotive brake cleaner melts the plastic
acetone doesn't take all the paint off
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-13-2004, 09:57 AM
Wedginator Wedginator is offline
I luv LEDs
here's my experience from plastic model windows. Some times there are scratches on it and sometimes glue accidentally gets on them... so I use very fine grit sandpaper (maybe 1500 grit and wet sanding) and sand it down evenly. In your case, sand it down until u get a smooth feel. Wash the peice in soapy water. U can use turtle wax or floor polish for this step. get a cloth, and in a circular motion buff the plastic. It should get clearer and clearer... since u are polishing a lens, it might be harder cuz it's such a small peice. Don't use a dremel cuz the friction of the buffer will melt the plastic.
Old 02-13-2004, 11:22 AM
theMonster's Avatar
Got Brains?
another option
find a cheap toy that's got a thick plastic bubble or buy a cheap lexan body from your LHS, take the tailights out of your car and use them as a stencil to cut the plastic bubble/lexan and use that to replace the red lenses, this way you don't ruin the lenses by accident and can go back to red if you wish.
This is your brain.....
Old 02-15-2004, 02:06 PM
NissanGTR01 NissanGTR01 is offline
Send a message via AIM to NissanGTR01 Send a message via Yahoo to NissanGTR01
if you wanna clear the tails on the civic the paint is on the outside of the lens at least mine was. then you just scratch the paint off gently with a razor knife or similar tool
Nissan Racing
KA24E
7500 RPM
280 HP
270FT-lbs
Old 02-15-2004, 02:21 PM
I'm afraid I'd scratch the plastic with a razor.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-15-2004, 05:04 PM
skklown skklown is offline
cover up the scratches with clear nail polish
xmod blue civic ricemobile.
Old 02-15-2004, 08:11 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Brake fluid *might* work, but I doubt it. I know it works on spray paint.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-15-2004, 08:37 PM
I found the best thing for XMOD lenses. All you do is soak them and wipe, soak and wipe... This is it...goof-off
You can buy it at most hardware stores. It somes in sprays also. The one I posted is the one I used.
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Command Logic Lights MODS drewdown84 XMODS Mods and Projects 4 07-30-2007 01:33 PM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
running lights from car battery esp rocker Bit Char-G / MicroSizers 4 06-24-2003 01:23 AM
putting lights in my car xatu Miscellaneous Discussion 12 06-04-2003 12:06 PM
Drag Race Lights DavidDeLaurier Bit Char-G Mods and Projects 13 12-30-2002 02:32 PM
