Old 02-11-2004, 04:01 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
need a new TX antenna?
i sure did, snapped my antenna in half. found a replacement though. the TX antenna was very similar to this antenna i had on a RC TX from a different scale car and the only difference was the XMod one was very slightly thinner. i looked at RS after finding out every RSU part was backordered and saw a similar antenna that they were selling. all three had the same screw in terminal on teh bottom but like the other antenna i found, it was slighly thicker than teh XMod antenna. all you have to do is get a rounded file and file out some of the plastic on the top of the controller where it the hole is. the hole is slightly smaller to fit the XMod antenna but the shaft behind it was wider and coudl accomodate a slightly thicker antenna. after i carefully filed out that hole, my new antenna fit perfectly in place. i coudl post pics but i didn't see the need to
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 02-12-2004, 08:51 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Is it longer? That would be a good way to boost range, if you use it in conjunction with a longer RX antenna.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-12-2004, 09:00 PM
TypeZer0's Avatar
0reZepyT
the replacement i found was pretty close to an optimal length (length is some quarter of the wavelength) for 27MHz, i calculated 28 or 54 inches to be quarters of the wavelength and the antenna is about 27 inches fully extended.
Old 02-15-2004, 07:09 AM
ppcheee's Avatar
ppcheee ppcheee is offline
sseiko sks195- mine :)
the antennas from clone bitchargs (the dome ones) fit in the controller also and are a bit longer.
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
stock antenna lenght big-key Bit Char-G / MicroSizers 3 02-23-2003 11:39 AM
The perfect antenna Mod...for anyone Johnaten ZipZaps 3 11-10-2002 09:32 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
