Old 02-07-2004, 10:02 AM
WhoMe WhoMe is offline
Cleanings bearings?
Im sure there are a few threads on this question..but whats the best way to clean out yours bearings? Some say soak in alcohol over night and lube in the mornin..is that cool?
PS I hope tiny comes out with their bearings soon ;_;
Old 02-07-2004, 06:15 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i soak mine in WD-40 every once in a while. but de grease them first. you can to that with Brake Cleaner. there are some more that you can use but i forgot.
anyone know how to free a rusted bearing? (damn steel balls)
NEVER UNDERESTIMATE THE POWER
Old 02-07-2004, 08:01 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Soak it in CLR. It works great to remove rust.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 02-07-2004, 09:04 PM
newbitowner's Avatar
I haven't cleaned my bearings. Is it really necessary?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-08-2004, 12:26 PM
neurokinetik's Avatar
It can make a big difference in performance. I soak mine in Simple Green engine degreaser. (I actually put them in a bottle and swirl them around in it for a couple of minutes) Then I switch to water to get the Simple Green out of the bearings. Next I pour them all out onto a paper towel and blot them dry. Then I douse them in Slick 50 One Lube, dry off the excess, and install.
Doing this procedure with the bearings new out of the box makes them faster than stock.
Old 02-08-2004, 01:07 PM
Thanks for the feedback Neuro, and your right it does improve the spin seeing as when i did clean them out as you instructed ALOT of gunk came flying out. Now i see why people are looking foward to these sealed bearings.
Old 02-08-2004, 08:12 PM
neurokinetik, I don't have any Slick 50 lube. Do you think motor oil has the same consistency?
I have 10W-30 and 10W-40 motor oils. Or maybe white litium grease?
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-08-2004, 08:25 PM
Ixnay on the grease. You want a lightweight oil that stays where you put it. You can get the Slick 50 at any hardware store for $1. Trust me, it's worth it.
Old 02-09-2004, 06:58 AM
TinyRC XModder
What is Slick 50's actual purpose?
What about 5W-30 oil? (new Accord uses it)
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-09-2004, 08:49 AM
Slick 50 One Lube is a synthetic penetrating oil that is light, extremely slippery, and tends to stick to metal. It is like a WD40, but much, much better in every aspect. Motor oil won't work nearly as well. Over the years, I've tried many different kinds of lubricants in my inline skate bearings, and nothing beats Slick 50. It lasts the longest, and performs the best. Everything else was worse in one or both aspects.
Old 02-09-2004, 07:36 PM
aperson's Avatar
so use Slick 50 1 Lube insead of WD-40 right? i got alot of that stuff lying around. and what is CLR? chlorine?
Old 02-09-2004, 07:44 PM
theMonster's Avatar
Got Brains?
CLR
CLR is a cleaner that is used to remove rust, lime and calcium build-up in plumbing, but it has many other uses as well. You can pick up a bottle just about anywhere (Kroger, Wal-Mart, WalGreens etc..) for a few bucks. Really good if your shower-head is clogged up too, just soak it in some CLR!!
This is your brain.....
Old 02-10-2004, 08:53 PM
DakarV's Avatar
DakarV DakarV is offline
I'll think of something..
Hey Guys, I'm planning to purchase bearings soon (only a few RS here in NY are carrying these). For those who already purchase them, do they come with grease? I plan to degrease them if they do and use some dry lube. The stuff I'll be using is Finish Line Bicycle Lube with Teflon (I use this stuff all over my bicycle, even used it in my bro's PlayStation 1 motor (still works)). Well, any opinions on this?
Old 02-10-2004, 09:27 PM
TinyRC XModder
No, they don't.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 02-11-2004, 07:05 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i remember mine came with grease when i bought it very early on, dunno about now. they put a dab of grease on one side of the bearings and stuck them in teh package. grease kinda adhered itself to the package, was a pain to remove (just cut my nails at the time..... )
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
2 the people who have race bearings... drewdown84 XMODS Parts and Hop-Ups 2 12-13-2006 03:36 AM
TinyRC's Bearings For XMODS. Bad Company XMODS Parts and Hop-Ups 128 12-08-2006 03:13 AM
Metal Bearings bengali548 XMODS Parts and Hop-Ups 4 06-26-2006 09:35 PM
Evo Bearings and Truck problems Lucky7 XMODS 1 11-28-2005 12:47 AM
FS: NIB Rs metal bearings Shiporu For Sale/Trade 1 05-16-2004 01:56 PM
