12-31-2003, 12:06 AM
GT3 Drift Master
breaking the tires loose
hey y'all. here is what im running for drifting.
awd
red front/blue rear
hard slicks all around
stage 2 yellow
5-cell
i think thats it. i see to still get too much grip. can someone help me out on how to break the tires loose without lube of some sort? i use the feint or power-over style.
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
12-31-2003, 12:35 AM
Well, if you can't lube or otherwise alter the tire surface, then I'd suggest using a different approach to the turn or changing the rear axle setup.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
12-31-2003, 01:00 PM
DRIFT KING
Did you use the LSD from the AWD kit? i just left it out and it seemed to want to drift more, oh and what kind of floor are you drifting on? i drift on a Raquet ball court, so i think your best bet is to use the masking tape method otherwise you get way to much grip on the rear wheels, hey just go get a 180 motor and i think you won't have a problem.
*Edit* slide your batts all the way forward too, that's gives a good amount of help with wieght transfer.
I don't care if you can you beat me in a drag, I'll own you in a drift match.
12-31-2003, 01:13 PM
RC Tinkerer
I would sudjest trying hard tred front & rear. Try the Stage 2 Purple. I did that, and when I hit the gas on a smooth surface, the tires spin before the car moves forward. On carpet, if you time it right, you can do a compleate rollover and land on the tires. (Remove your mirrors or you might break them off)
12-31-2003, 04:15 PM
GT3 Drift Master
first, im running on polished walnut. second, i moved the batteries to the front. third, i hear that hard slicks give the least grip. this is what i'm using. i have red springs in front, blue in back. i think i just may have to use masking tape.
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
02-06-2004, 06:27 AM
sorry for getting off topic, but I was wondering about the  thing...is that for the x-mod...if so how do you go about doing it...thanks for the help
02-06-2004, 06:38 AM
Man you cant drift the thing????
How strong is the drive train in these cars, would it take 10 times the stock power????
02-06-2004, 10:05 AM
i just put some ZZ tires on a set of extra rims and i put them on just the rear for now but they give a little less than the hard slicks i was using. those might help
02-06-2004, 10:50 AM
bite my shiny pimpmobile
softs in the front
02-06-2004, 11:54 AM
TinyRC XModder
Go with the drift motor, it's called that for a reason.
Also, just experiment with springs, thats probably the best way to go at it.
EDIT: I just saw that you're running alkalines.  Rayovac IC3's are your best bet.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-06-2004, 01:00 PM
Am I missing something?
No one has said anything about the AWD setup. Wouldn't a RWD setup be more conducive to drifting?
Not that you can't drift on AWD, I just thought it was easier on RWD.
02-06-2004, 01:12 PM
Got Brains?
wha????
I had NO trouble drifting with EVERYTHING being stock other than 6-cells and stage-2 yellow. I'd suggest losing the AWD.
This is your brain.....
02-06-2004, 03:26 PM
Re: wha????
BAM thats what i'm talking about.
02-06-2004, 03:54 PM
DRIFT KING
in rc's it doesn't matter what drivetrain you run, because the thing is only so big, using the awd is just more forgiving so you don't have to use extreme steering to get the thing to drift. and as for the springs yellow up front rather thatn the red is a much better setup, i tried them all and it seemed to wark the best, and as for tape, just masking tape them, it's not cheating it's improving a design.
TinyRC XModder
Re: wha????
I find it near impossible to drift with RWD, at least on a concrete floor. I'm not sure what you consider "good" drifting (maybe upload a video of you drifting?), but when I try to drift with RWD I end up spinning out every time. I've tryed every style and I've yet to be able to do anything I'm satisfied with.
I also haven't seen anyone else able to drift with RWD. So I'd like to see what Schr-eng and theMonster consider drifting.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
