01-24-2004, 08:45 AM
Keep the dust out (rally guys)
01-24-2004, 09:53 AM
Good addition to the skidplate.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
01-24-2004, 01:41 PM
I tried to do a rear one just now, but it needed too much trimming and it lost functionality so ill keep the front only.
01-24-2004, 03:33 PM
Go Banana!
cool man. i'd love to see a lift kit as well. Rallying would be a neat thing with these.
01-25-2004, 08:08 AM
I am going out right now and try to run it off-road (RWD) and see how it goes. I might attach the read mudflap to the body instead of the chassis.
01-25-2004, 08:01 PM
this is awesome. when i get at least one of my cars going again, ill need to make me some of these. ill probably integrate them into my new skid plate though.
01-25-2004, 11:48 PM
Hardcore Otaku
aww man, I thought you meant keep the dust out of the gears! I am getting a lot of dust even in the tennis courts! I can only imagine how much more on dirt... Maybe I'll attempt to seal up the drivetrain myself... and longer susp. arms and a lift kit as well
01-26-2004, 10:26 AM
MY ENZO!!!!!!
i figured out how to do a lift kit but it is really hard to explain. when my dremel starts working again i will try it
01-26-2004, 12:39 PM
Hardcore Otaku
Yay! Hard to explain? Could you at least try?
01-26-2004, 01:05 PM
MY ENZO!!!!!!
ok i will do my best
first you have 2 dremel out a section of plasitc under the u joint. Then you have to take the suspension out, after that you fill the place where the bottom of the suspension is held in. After that has dried drill a small hole directly under the a-arm mount, then place the suspenion in normally. This makes the a-arm higher than usual causing a lift in the rear, formally known as a lift kit. Iam sorry nothing for the front yet. That wasnt as hard as i thought it would be
01-26-2004, 01:12 PM
Hardcore Otaku
O.O That's it? I get it
01-26-2004, 05:36 PM
MY ENZO!!!!!!
Thats it, for the rear. However i have no idea about how 2 do the front. I thought it would be much harder 2 explain
01-26-2004, 07:22 PM
Did you do It yet?
Does it actually work?
How much more rideheight did you get?
Can you post a pic if you did?
This (if it works) would realllllll big to me and all other rally guys
01-26-2004, 09:10 PM
MY ENZO!!!!!!
sorry but no dremel yet. but i would say it would be about a 1 inch lift. next time i go to my friends house maybe we can use his dads dremel
01-26-2004, 10:51 PM
You guys should also add this simple mod...
See the shield?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
