Old 01-06-2004, 01:21 PM
mystiquesupra mystiquesupra is offline
Upgraded Wiring
This question is for the advanced x-moders
I was wanting to upgrade my wiring since I am buring the wires on my xmod over and over again.
I saw some people whom had 16g wire installed. I had some high quaility 16g wire and found that sodering to the esc is a tricky task. The holes in the board are just big enough for the stock wire to fit thru, the 16g is much larger then what the board will accept
is there a way around that, or a trick I dont know about? Can someone offer advice on how I can get this wire on my board so I can complete this upgrade.
Thanks
Old 01-18-2004, 02:50 AM
igoren igoren is offline
UPGRADE WIRING
IN ORDER TO REPLACE THE WIRING IN THE ESC YOU NEED TO
REMOVE THE OLD THIN WIRES BY HEATING THEM UP WITH
A SOLDRING GUN AND THAN REMOVE THE EXTRA SOLDERS WITH
SUCKER. WHEN YOU GET TO THE EMPTY HOLE USE A SMALL DRILL BIT TO ENLARGE THE HOLES TO FIT THE 16 GAGE WIRES.
BE CARFULE NOT TO DUMADGE THE CIRCUIT BORD.
I REPLACE ALL THE WIING IN MY XMODS TO 16 GAGE WIRES.
IT WOKS VERY WELL.
ig
Old 01-18-2004, 06:40 AM
Bad Company's Avatar
igoren,
Welcom to the forums. Please try not to type in all caps, it makes it a little harder to read.
Thanks
Old 01-18-2004, 11:00 AM
scatmanjohn01 scatmanjohn01 is offline
if you do try making the holes bigger, try not to ruin the gold disks that the wires connect to, or else it will be very difficult for the solder to stick to the board
Old 01-18-2004, 12:05 PM
upgrade wiring
i use a hand drill ( not electric ) to gentel enlarge the holes,
and also you can trim few thrend from the wire tips befor insert
into the hole and have the wire insulation fit tight against the
circuit board and solder from the back.
it is very delicate job ,you need to disasambale the entier board
and be carfull not to dumadge the other wires to the servo
and speed control.
in my mini cooper - italian job i added charging plug to the battery
asambly so i dont need to remove from the car for recharging.
ig
Old 01-19-2004, 12:16 AM
97Supra's Avatar
97Supra 97Supra is offline
i have a fried x-mod and so what ur saying is upgrading the gauge will stop it from frying again with the new pbc/or reciver I am getting ?
Old 01-19-2004, 12:49 AM
no, upgraded wiring will have better current flow. nothing can prevent you from accidentally touching your battery lead to your anrenna wire (like you did).
Old 01-19-2004, 04:27 AM
codedat
You can use electrical tape on the end of the ant lead to avoid making the same mistake in the future.
Old 02-04-2004, 09:08 PM
newbitowner's Avatar
what gauge wiring is stock?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-04-2004, 10:03 PM
I Shall Return!
~this is kinda neuby but when you guys say you replace all the wires, is it ever sing wire on the electronics circuit (excluding the wires leading to the light connector) or are you guys simply replacing the motor and battery wires
~the guage i suspect to be between 18-24 but this is only a eye worthy guesstimate
~as for the hole problem, when i had to reconnect all the wires in my tx (broke the ribbon wire) i used a small paperclip to clear out the hole.. as for he fitting issue you could just try to get as much of the wire in the hole, and then flat solder the rest..
~random issue- should i put back my .02$ avatar or keep this?
Old 02-04-2004, 10:27 PM
spinitsidewayz!'s Avatar
boro dori style RC
how much better flow would upgraded wires give? like performance wise. would it make the car considerably faster?
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-05-2004, 12:01 AM
spitty12's Avatar
spitty12 spitty12 is offline
Happiness is a warm gun..
Send a message via AIM to spitty12
I have a 5 cell sb hybrid and I didn't notice any performance gain on the wire upgrade. I upgraded all the wires too. To make the wire fit in the hole I trimmed of a couple of strands and made sure to hit both sides with some solder.
Old 02-05-2004, 09:13 AM
i personally think single strand is best.
Old 02-05-2004, 11:36 AM
theMonster's Avatar
Got Brains?
16awg???
Gawd that's awful thick wiring, I can only amage how clunky it looks and how heavy it is....
This is your brain.....
My wiring dream/nightmare... Delorean Freak XMODS Gallery 12 03-07-2005 08:30 PM
Wiring Help!!! TheBlueYenko ZipZaps SE 0 02-13-2004 05:11 PM
help, i need a picture of controller curcuit wiring MTL Bit Char-G / MicroSizers 3 12-28-2002 09:43 PM
cat5 antenna for internal wiring 8ate8 Bit Char-G / MicroSizers 5 12-26-2002 04:59 PM
A question on pcb wiring DabEAn Bit Char-G Mods and Projects 4 11-25-2002 10:36 PM
