Old 01-17-2004, 10:09 PM
SupraMan017 SupraMan017 is offline
Type-R
Send a message via AIM to SupraMan017
Question
Would a 5th cell mod fry a stage two motor? Or is it the same as with 4 cells?
My XMOD:
Acura Integra Type-R
180 Motor with Drag Pinion
6-Cell Upgrade
FWD
Locked LSD
Hard Springs Front and Back
Soft Slicks in Front
Hard Slicks in Back
Old 01-17-2004, 10:17 PM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
NO i dont think so unless u run it that long anywayz 5 cell only makes a longer run time
Old 01-18-2004, 12:33 AM
R33E8 R33E8 is offline
No, it adds more power.
Xmods Civic:
Old 01-19-2004, 08:13 PM
aperson's Avatar
aperson aperson is offline
i believe that a 5th cell adds runtime and 6 cells add power
Old 01-19-2004, 09:19 PM
LOL
If you want to add run time, you wire the extra battery up one way. If you want to add power, you wire the battery up differently.
Thats the difference between running the batteries in a parralel or a series.
The extra 1.2-2.4v won't fry your motor. The motor itself can handle quite a bit of voltage(more than 12v).
Old 01-20-2004, 09:09 AM
aperson's Avatar
thats right the motor can handle more than 18 volts but the electronics are the problem. without some serious modding or replacement w/ stronger electronics they wont take more than 9 volts.
Old 01-20-2004, 10:31 AM
Quite a few people, and I have no reason to not trust it, consider 8.4v the max that the stock ESC can take without damage - atleast for extended periods of time.
Plz Look!! Slipper And Or Tranny Question! lilrichie1306 Micro-T General 3 01-24-2008 03:22 AM
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 08:39 PM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-26-2002 12:32 AM
Question about model putty... SPEED Bit Char-G Mods and Projects 1 09-28-2002 11:19 PM
Question about fullsize wheels set Mod..? SPEED QFM Racing Customer Support 5 09-25-2002 12:26 PM
