Old 01-08-2004, 06:39 PM
Drag00n Drag00n is offline
Hi Experts, I dont really understand how to do the ZZ rim mod...
Hi Experts, I dont really understand how to do the ZZ rim mod..., If I buy a Zipzap set with the rims, How can I change them with my BCG ones? Does require any cutting or drilling?
Old 01-08-2004, 07:21 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
no drilling or cutting.....just getting upclose and personal with the stearing mechanism in your car.......open the pcb and unscrew the stearing cover, open that up and remove the original knucles. put in the newones exactly how the old ones were and put it all back as when you first opened it up......now close it up, screw the cover back on, and your done!
-Andres
Old 01-08-2004, 09:08 PM
Sweet!
Cool! No glue, drilling, cutting? Nice... wow this is 1 of the easiest mod then... even easier than the NIMH installation Cool! But since the front wheels will be bigger.. will it interfear with the steering? I hope you dont have to do other mods for it.. and the back axle.... does it fit nice and tug in a BCG?
Old 01-14-2004, 04:34 PM
viperdout's Avatar
It's Really Fast!
Wait! BC-G knuckles don't work on a ZZ! ZZ knuckles might be too big. They also might lock up on a turn. You have to switch knuckles.
Project Bad Brushless:
Just say no to giant sigs.
Old 01-15-2004, 11:15 AM
MicroSpeed's Avatar
All you have to do if they're too big is drill the holes out (the ones that the knuckles fit into) a little bigger. I used a drill press, but if you don't have one simply hold a drill bit in your fingers and twist it around in the hole.
Old 01-15-2004, 01:04 PM
they fit!!! no problem with fitting the knucles...ive done it many times.....and it works too....
this mod is 100% cutting and glue free.....
happy modding
-Andres
Old 01-15-2004, 01:14 PM
proof:
-Andres
Old 01-15-2004, 01:25 PM
viperdout's Avatar
It's Really Fast!
Well, then I'm wrong. Thanks for the heads up, Boris. My LXX knuckles don't work on a ZZ, so I'm not swapping.
Old 02-29-2004, 06:23 PM
filelicker's Avatar
filelicker filelicker is offline
Bits are my drugs!
Send a message via Yahoo to filelicker
I side with boris I have many zips with bit knuckles[just have to open up the holes in the chassis where the knuckles go in} my zips werew binding really bad till I opened up the holes and many bits with zip knuckles.it works good really and is cool!
ZZ Rim mod.....Tell me the truth please. Drag00n Bit Char-G Mods and Projects 1 01-09-2004 07:38 PM
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
