Old 01-09-2004, 08:11 PM
Railside270's Avatar
Railside270 Railside270 is offline
Topsoul to 540 out
Send a message via AIM to Railside270
Question Gear Probs...!!
Ok...i have searched the threads for a possible fix to my problem....no luck. So here it is:
I have this grinding noise and gear slipping when i run my car. If i try to drift there is a weird noise that sounds like clattering but much faster. I dont know what is causing this so please help
RCtunerzforum.tk
Your source for micro RC tuning!
Back Up My Hard Drive? How do I Put it in Reverse?
Old 01-09-2004, 08:16 PM
aperson's Avatar
aperson aperson is offline
every once in a while i have the same problem. i take the rear end out and clean everything. especially check if the driveshaft is in the spur gear correctly. take the screwdriver and clean the differential. if you have bearings or AWD make sure to clean all of that too.
charliebrown's Avatar
Check the gears and see if there is anything wedged in them. See if they are properly installed, and try greasing them with a lubricant. I will see if I can find the correct one.
[Edit] this is it, http://www.radioshack.com/product.as...t%5Fid=64-2301
Chuckster...
Old 01-09-2004, 08:34 PM
Topsoul to 540 out
Thx guys...ima try that stuff tonite. I cleaned my diff b4 when i had a loud screeching noise and cleaning it stopped the noise. Maybe if i clean it some more it might stop the prob.
RCtunerzforum.tk
Old 01-09-2004, 08:44 PM
Glad to help!
Old 01-09-2004, 10:43 PM
Topsoul to 540 out
AHH! no use...
well i cleaned everything that the gears connect to...lubed it with litho-sumthing grease...changed the motor. its still the same! there is still this grinding/skipping noise coming from the gears. Plz help if anyone knows the exact problem...
RCtunerzforum.tk
Old 01-09-2004, 11:58 PM
Topsoul to 540 out
just in case nobody knows what im talking about...i attached a recording of the noise that my car makes when i rev it in my hand. Before i switched the motor, it didnt have that screeching noise, it had a weird grinding noise instead. When i run the car on the ground, the screeching disappears but then the grinding noise comes back.....Click here to listen (you may have to right-click and save target as)
RCtunerzforum.tk
Old 01-10-2004, 03:05 PM
Topsoul to 540 out
I just found out the only the drift motor makes that screeching noise. The drag motor makes the grinding noise, the road race makes an even louder grinding (and is very very slow now...the gears slip) and the top speed barely even moves (but you can hear the gears slipping) I know its not the motor because i have checked. Its something with the gears or the diff
RCtunerzforum.tk
Old 01-10-2004, 08:32 PM
Topsoul to 540 out
ok...Today i just figured out that the diff and the spurr gear dont get enough contact. Is there any way to fix this? anyone?
RCtunerzforum.tk
Old 01-11-2004, 01:21 AM
Topsoul to 540 out
Can someone please help?! i want to run my xmod...im bored
RCtunerzforum.tk
Old 01-11-2004, 01:50 AM
itsme
MMM...You know those two screws that attach the back end to the middle chassis piece? Try taking those out and putting them in again, make sure that it goes in all the way and not crooked. I've had that problem before. Yours might be different.
Old 01-11-2004, 01:55 AM
Topsoul to 540 out
Theyre not in crooked...they're straight. They go all the way in.
RCtunerzforum.tk
Old 01-11-2004, 01:58 AM
itsme
Out of ideas... But maybe you could take a few pics of different angles?
Old 01-11-2004, 03:23 PM
Topsoul to 540 out
Pics of...? the gears?
RCtunerzforum.tk
Old 01-12-2004, 08:41 AM
aperson's Avatar
yes the gears. did you check if the rear driveshaft holder was broke? try reseating that. you have to remove the motor, take the screws out and put them back in and put the motor back in. that might help. did you check the pinion? see if something is in it.
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 05:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
gear probs Lord_HelmetR34 XMODS 3 12-27-2003 09:05 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 06:34 PM
