Old 01-07-2004, 03:06 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
a more NOS'like' idea
I read somewere on here that there is a fluid that you put in slot cars and it makes the motors really fast for a couple sec. My idea is that you could have some type of tank with this fluid in it and it would drip slowly into your motor. I don't know if this would work or if it would ruin your motor, so tell me what you think.
--Chris
Aka...aero528
Old 01-07-2004, 04:44 PM
Joey's Avatar
Joey Joey is offline
You'd need to (1) find out if this actually exists, what it is, and whether or not it'd work with the XMODS motors, (2) make a tank and hose system for the inside of the car, and (3) somehow make up the weight that system will put on by chutting other stuff off.
If it's only a few-second boost, it's probably not worth the trouble.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-07-2004, 04:50 PM
aero528's Avatar
like my dog??
yeah i agree and i will do that sometime soon.
it would be a constant boost because the fluid would constantly drip into the motor. i thin that the weight of the system would easy be nothing compared to the boost. i will look it up.
--Chris
Aka...aero528
Old 01-08-2004, 07:33 PM
colin4371 colin4371 is offline
PPG Co-Owner
it sounds like this is something for nitro cars, like a higher octane fuel. i dont think theres any kind of electric motor that can be better running with some liquid dropped into it, but i may be wrong.
Old 01-08-2004, 07:43 PM
aperson's Avatar
aperson aperson is offline
it could be some kind of super conductive oil. then a new problem arises, does the motor "eat" it or does it drip out the bottom. if it just drops out the bottom youll need to make a way to protect the electronics.
Old 01-08-2004, 09:15 PM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
well, in my nitro rustler, i run 30 percent. it makes the engine run hotter, but it gives more power. for a elec MOTOR (btw, im sick of seeing wrong terminology. MOTOR is for electrics, ENGINE is for gas), u would need someway to channel that power. no product dripped on to the engine will do anything. it will be more of a hindrance than a help. but if u want like a router and u have an extra servo, then u could get the throttle up, then open it up all the way with a button. that would be likw a nos kinda thing. my dad's friend's son did something like that to his HPI sprint.
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 01-09-2004, 08:18 AM
aperson's Avatar
but then that would require a whole new electronic system and a reciever w/ 3 channels
Old 01-09-2004, 12:51 PM
Jofir Jofir is offline
Send a message via ICQ to Jofir
it sounds like a good idea...
very improbable but hey, good luck dude
Old 01-16-2004, 04:11 PM
SonicKuz SonicKuz is offline
Send a message via AIM to SonicKuz Send a message via Yahoo to SonicKuz
I heard about these on the mini z boards. The tester swore by it, and it sounded believable. Not that it made a world of difference, but it helped. Maybe it was some special conductive com drop.
You can also use special commutator or com drops in your motor, which are suggested for use a drop every now and then. They help, a little, I think. Any LHS should have them.
What goat?
Old 01-16-2004, 04:27 PM
Exaran's Avatar
Exaran Exaran is offline
Send a message via AIM to Exaran
I have some stuff around the house called "Formula 96". I had it for my 1/10 RT-10T. You put some on the communicator to help break in the brushes, I think...
Sliver Xmods Skyline
Old 01-16-2004, 05:32 PM
Yeah those are com drops and other motor treatments.
You can cool off your batteries and motor with canned air if you know how to spray it right...
What goat?
Old 01-17-2004, 04:38 PM
aperson's Avatar
hmm... spray it right. you mean upside down so that the liquid comes out right?
Old 01-17-2004, 04:50 PM
I'm not too sure if you need the liquid. It seems to do funny stuff when it actually drips out. Plus, if a lot of it gets on your fingers, it hurts like hell (happened to me before). I have tons of cans of this cheaper stuff and if you tilt it down a little, it lets out a little more mist than usual and can make the motor cool off.
What goat?
Old 01-17-2004, 05:14 PM
aperson's Avatar
drips out? mine comes out like a bat out of hell. i sprayed it onto an old cd spindle case and it started to get frost all the way through it. i also used to play with my ZZs & test their areodynamics with the stuff until it burnt me.
nitrous idea bengali548 XMODS Parts and Hop-Ups 6 07-20-2006 01:00 AM
)(-Mod Neon Idea xxspeednplayaxx XMODS Mods and Projects 17 12-12-2003 05:04 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 05:30 AM
