06-12-2002, 08:33 PM
What is your favorite track material
What is your favorite track material and what kind of tire set up works best for you on it? I'm THinking about making some tracks.
Thanks for your opinions.
Bit Char G Booster's all of them.
06-12-2002, 09:28 PM
I've played around on a vinyl mat available at some gaming stores. It gives the cars great traction and handling. Adding jumps is too easy as well. All you have to do is put a wrinkle in the mat and voila... instant jump.
The next best thing I've raced on was a track on a billiards table. This was great because of how huge the thing was. Still great handling but a bit more roll resistance and no easy jumps.
My kitchen floor sux because it is just too slippery. I've tried different tyre combinations with no great success.
06-13-2002, 12:06 PM
Shoot To ILL
I've been using this thick cardboard foam core stuff that the softs really stick to nicely, very easy to race on because you get awesome traction, an for the walls, you can actually embed balsa wood sides to it. woodglue works really well on it too
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
06-13-2002, 05:07 PM
i think a really good material would be the underside of a mousepad. or atleast the mousepad that i have. its brandless, but the underside has no grooves or anything. its a solid slab of some sort of dence foam. its black and pretty solid, yet couchy. it also has reasonable grip.
06-13-2002, 09:42 PM
Redneck Drifter
i use sheets of paper, they work really well the only problem is too much traction it turns really sharp.
06-13-2002, 09:59 PM
Pool tables
Earlier I recommended playing on a pool table because of the great performance I was getting.
Today I've changed my mind.
I spent way to long cleaning green fuzz out of the motor area and wheels.
As for the mouse pads, I think you'd have just a bit too much traction.
Cardboard does work well and is easy to get.
The vinyl is still my fave though. The ease of making good jumps was worth it alone and the fact that the whole thing rolls up into a nice tube makes it great for storage.
01-05-2004, 02:50 PM
Hi all I am going to try and bld a track, I am going to use a sheet of dry wall I am going to draw the track on the sheet first then I am going to paint road surf. with chalkbaord paint. I have some flex plexi glass that i think i am going to cut in to strips for railing and use some plexi for a over pass or two. So any sugestions or idea send them my way I am open to any thing. i will try and post pics as i go !!! m
Toyota supra 2.2 motor light blue gears!
01-05-2004, 04:46 PM
I don't have tons of experience with surfaces, but my favorite right now is the brown wrapping paper that comes on a ream and you can simply tear off how much you need.
The stuff can be rolled up and stored easily after use, and it has good traction without being too grippy or too slippery. I use medium tires up front, and softs in the back. I may go up one more step to hard in the front and medium in the back, but I haven't tried it yet.
I am currently building my very first track. It is made with three sections of plywood, but I havn't figured out a good way to join them yet. I'm going to price piano hinges when I get a chance. Anyway, I have covered one entire surface with the brown wrapping paper, using the spray on adhesive.
01-05-2004, 04:55 PM
You can't beat it.
I like glass, it gives the cars plenty of traction but it doesn't come in black like vinyl does, so vinyl
My Garage: One Lamborghini Jota, Murceilago, Diablo, and a Countach.
One Ferrari Enzo.
One Porsche 911 GT2s, and 1 911 Turbo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
And 4 dozen Toyota Supras, 6 Skylines, and a Hino Blue Ribbon Bus from the Keisei Line.
01-06-2004, 06:59 PM
Paper
Paper is the best.
01-07-2004, 07:29 AM
i need the track width for 4 cars racing if ne1 can help
hehehe
01-07-2004, 01:46 PM
Confirmed: Lost In Fog
hehehe.....my track is on plexiglass.............great for high speed, but suck for turning.......plus, i made my track too tight
-Andres
01-07-2004, 05:11 PM
Comrade do you have a pic of yur ple glass track and did you make a overpass??
01-07-2004, 06:02 PM
i didnt have any space for an overpass.....heres a pic from when i still had only ZZs....
[img]http://groups.msn.com/isapi/fetch.dll?action=MyPhotos_GetPubPhoto&PhotoID=nFAB uAEUDdBKQDlqRB*kMFAp468YAJIZ9MZbP73ZBRPZSLitjKJGbC w[/img]
if that dosent work, heres a link to the old site.....: http://groups.msn.com/zipzaprc/zipzaptracks.msnw (mine is at the bottom)
-Andres
