Old 12-28-2003, 10:53 PM
lemans23's Avatar
lemans23 lemans23 is offline
GT3 Drift Master
drifting help
hey everyone. im a drifter with the wrong stuff i think. i have a 5 cell mod, a rwd rsx, no suspension upgrade and the yellow motor with tire upgrade. the motor is stage 2, and when i use the drift one, it will spin forever cause of the torque. once i get a dv device for my pc (can someone explain that to me? i can't import video without it) i will post some good vids. my drifts around the counter island in my kitchen don't work 2 well. sometimes i get good ones, but usually the rear end grips 2 much and i can hear it skidding. can someone tell me how to make it actually SLIDE instead of like stuttering across so i can have it more smooth? the floor is like mahogany or walnut or oak or something. it is polished and has pretty good grip. im running hard slicks all around.
Bit Char-G= FRIED WITH 4.0 MOTOR
RSX XMOD:
Stage 2 yellow motor
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 12-28-2003, 11:11 PM
RC 2NR RC 2NR is offline
TinyRC XModder
An AWD kit would help a lot.
Old 12-28-2003, 11:28 PM
pbmax's Avatar
pbmax pbmax is offline
Li-Ion Addict
Here's a stupid / crazy thought: Lube your tires?!?!?!?
pbmax
Old 12-29-2003, 12:41 PM
maikeru's Avatar
maikeru maikeru is offline
DRIFT KING
Send a message via AIM to maikeru
what i have found to be the best is to put a strip of masking tape on each tire sticky side down, then go and run it on cement for like 5 minutes, come back inside and whipe off the dirt that's prolly on it, then when you start to drift you will have just the right amount of Grip and the right amuont of slip, enjoy!
Old 12-29-2003, 06:22 PM
3series takumi's Avatar
mini-eX-Driver
your biggest fault there in your drift setup is you have an RSX j/k i would try put better magnets in your motor to increase torque. what drift method are you using?
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 12-29-2003, 08:07 PM
lemans23's Avatar
GT3 Drift Master
it depends. sometimes i use the feint style or i use the kinda power over tech where u go in at full throttle and throw the car into the corner to break it loose. 2maro, im buying the suspension upgrade and the AWD upgrade!
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 12-30-2003, 01:16 PM
maikeru's Avatar
DRIFT KING
hey lemans23, when you get the springs use the hardest ones in the back, people say it's not so good but if you intend to drift it will throw the rear end out just enough to pull amazing drifts, i have the front set w/ yellows too, that i have found to be one of the best setups so far. i can pull keiichi style 4- whell drifts with that set-up
Old 12-30-2003, 03:52 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
can someone please explain the diff. styles of drifting?
Old 12-30-2003, 03:58 PM
mini-eX-Driver
the ones i know of that are possible by rc are
fient- turning away from the turn b4 cutting in towards the turn to induce slide (great for all types of cars ff, fr, awd)
powerover- gettin off the gas slightly turn then hit the throttle to reduce rear traction (i dont think it is possible on a ff setup)
break drift- taping the break right as you turn to reduce rear traction (only really works if you car is rear wheel drive cause electric cars break with what ever wheel powers the car)
there are a few more but i cant think of them right now. the fient and power over are my drift of choice
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-30-2003, 04:51 PM
lemans23's Avatar
GT3 Drift Master
nice. keiichi is a pro. i'm downloading some videos of him drifting a porsche 911 gt3
RSX XMOD:
.5 cm
Hard slick rear
hard tread front
5 cells
ALL ALKALINE
Old 12-30-2003, 07:47 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
Well here's a couple of drift techinque's.
Clutch Kick , Power drift or "PowerOver" , E-Brake , Preturn Drift "Rally Drift" , There's the brake drift which is pretty simple , Inertia Drift , And there's a Technique used for under powered cars were you drop your front wheel in the ditch to cause oversteer and then drift through it.
I think these are pretty accurate if not feel free to correct Me.
Peace!
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
Steering & Suspension upgrade.
1.5 steering rod.
Yellow springs all the way around.
Soon to come: Body kit
Old 12-30-2003, 07:59 PM
mini-eX-Driver
hah the gutter drift is from initial d :P
i dare anyone to clutchkick drift an Xmod!
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-30-2003, 08:02 PM
Got 4.2 King? I do : )
i can clutch drift an xmod
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 12-30-2003, 08:04 PM
mini-eX-Driver
sweet you got a transmittion!! what a 5 or a 6 speed tiptronic j/k :P
i would like to rig a 2 speed though!
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-30-2003, 08:06 PM
yeah a 2 speed would be tight. have like a 8 tooth and a 13 tooth so it can get moving and then jet away
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Drifting iphong XMODS Gallery 11 01-03-2007 09:40 PM
Drifting an Xmod rody XMODS 1 01-01-2007 09:25 PM
duall cells for drifting boho Bit Char-G / MicroSizers 10 07-14-2003 08:37 AM
