Old 12-29-2003, 10:17 PM
census007's Avatar
census007 census007 is offline
Drift withit
my car wont go straight help me
my car wont go straight. i know the first thing you are going to tell me is use the buttons on the controler.... i tried it still pulls to the left is the any thing else i can do to fix my piece of ****
A man that has made no mistake, has made nothing at all, and i have made alot.
White Supra
awd
C-logic kit
Stage 2 Motor Kit
Body Kit
Spin Brush
Old 12-29-2003, 10:43 PM
hoopsta1423 hoopsta1423 is offline
addin onto that ?, when i do use the button to set it straight then shut thew car off, it return to the stock setting, is there a way to keep it how u set it so u dont have to do it every time u turn the car on?
Old 12-29-2003, 10:54 PM
duwain
well you could just reset the steering servo arm thing that comes out of the front of the electronics part of the car. alls you gotta do is unscrew the little white thing that attatches to the tie rod, and make the little lines line up, screw it back on, and you shouldnt have to keep reseting the steering trims. BTW i read this on another thread.
Old 12-30-2003, 12:35 AM
Got 4.2 King? I do : )
yep reseting the arm works. after you turn on the car and the transmitter (with the arm off) just line up the line on the arm with the line on the chassie and it will drive strait when you turn on your car
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
during throttle, car accelerates not straight yeti Dynamite Rocket Racer 4 02-01-2004 12:28 PM
during throttle, car accelerates not straight yeti Dynamite Rocket Racer Parts and Hop-Ups 3 11-16-2003 12:55 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 12:59 AM
HELP! Car Stutters, etc. DrakZ1 Bit Char-G / MicroSizers 4 09-13-2002 05:25 PM
