Old 12-28-2003, 12:30 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i dont think tripod allows direct linking to pics, that's why i can't see it. same goes for the link right below it
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-28-2003, 07:09 PM
matrixled
Try here
http://evomod.tripod.com
Old 12-29-2003, 07:49 AM
neurokinetik's Avatar
I'll draw another diagram when I get home tonight...
Old 12-29-2003, 01:59 PM
miketre miketre is offline
Originally posted by TypeZer0
hmm, have you thoguht about connecting the source directly to the battery? would probably give you slightly less of a voltage drop
Connecting the source directly to the battery also allows you to mod it such that only 4 cells go to the board (and light kit too?) while all 6 cells (or whatever number within the FETs' limit) go to the motor.
Here it is on a Z, but the same concept should be applicable. ->My multi-cell mod
I'm just throwing in ideas, don't flame me for being a Z-lover I do hope that RS decide to market the XMods over here.
P.S. Nice work Neuro!
Old 12-29-2003, 02:40 PM
LithiumXmod LithiumXmod is offline
My finished xmod
LithiumXmod
Mods:
4 Cell CR2's Photo Lithium Batteries
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Suspension - Front: S Rear: H
Steering - 1.5 degree Tie Bar
Coming soon:
Ball Bearings
Old 12-29-2003, 02:42 PM
another
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-29-2003, 04:59 PM
I take it that it all fits under the body now? It looks much better.
Old 12-29-2003, 05:03 PM
[quote]Originally posted by miketre
[b]Connecting the source directly to the battery also allows you to mod it such that only 4 cells go to the board (and light kit too?) while all 6 cells (or whatever number within the FETs' limit) go to the motor.
I have to look at the board again and confirm the connections. There's probably another revision to be made. Doing it that way would allow for nice beefy wires that go right from the batteries, through the FETs and into the motor. It would also mean less connections to the circuit board would be needed, which would help in reliability.
That link looks like a good idea. I may have to try something like that. Hell, at that point, why stop at 7.2V? I'd go straight for 12V...
Old 12-29-2003, 05:24 PM
yup, everything fits under the body now.
http://tinyrc.com/forums/showthread....threadid=16760
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-29-2003, 06:22 PM
Alright, now this should be totally clear to everyone...
*non-working circuit diagram removed. See below for the correct one...*
This is the as-yet-untested version with the sources connected directly to the batteries. That might also be a good place to wire in a power cap...
Old 12-29-2003, 09:50 PM
matrixled
Thanks this helps out a WHOLE lot
Which 7 pins connect back to the main board?
Old 12-30-2003, 12:10 AM
I will the circuit later tonight. Im at work right now.
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-30-2003, 02:37 AM
Originally posted by neurokinetik
That link looks like a good idea. I may have to try something like that. Hell, at that point, why stop at 7.2V? I'd go straight for 12V... [/b]
Hmmm.... I don't think going more than 6 cells with a 35turn motor (S0-3) is a good idea. 12V should be less damaging to a motor with a lower current draw.
neurokinetik -> how's the battery life with the T0-220 FETs? Is it much shorter?
Both P and N channel FETs must be logic level ones right?
Old 12-30-2003, 02:39 AM
I just try the circuit, is doesn't work.
LithiumXmod
Mods:
10000uf power cap
upgraded FET's
Pnracing S03 motor
All Wheel-drive
Command Lights
Coming soon:
Ball Bearings
Old 12-30-2003, 07:27 AM
I haven't noticed any battery life differences, and I really didn't expect to see any. Both P and N channel FETs are logic level.
As for 12V damaging the motor, well, for my drag car that wouldn't be a concern. The 180 motor is designed to run on 6-12V, and that's straight from Mabuchi. Plus it only really has to last about 5 seconds or less...
OK, then here is the circuit that has been tested, and does work. Note that Pin 1 on IC5 and IC6 is the same connection, so as long as you tie the sources of both IRL3705Ns together, only one wire needs to be run to the board to make that connection, hence 7 wires needed instead of 8.
Are lipos and FETs worth it? Answer here Jazz32 XMODS Parts and Hop-Ups 24 10-29-2006 08:54 PM
Stock FETs max Amps? 4Runner XMODS 2 05-03-2005 10:53 PM
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Smoking Xmod!!! 4562 fets? chc XMODS 6 09-21-2004 01:42 PM
