Old 12-26-2003, 04:24 PM
seth98es's Avatar
seth98es seth98es is offline
Wiring AA help...
So I am trying to wire 2 AA batteries into my Xmod. I am not using ANY of the AAA batteries, just 2 AA batts. So I bought one of those 2 AA battery holders from RatShack and wired the red wire to the red wire on the Xmod and the same with the black. But I turn it on and only can get the steering to work. The motor will not turn. Ive tried several different motors and I know it is not the motor. How am I wiring this wrong?
I have 4 2000mAH RatShack rechargeables right now and am going to see how just 2 of them do. Here is a pic of it wired right now(dont pay attention to all of the dirt and grime!)
Old 12-26-2003, 04:31 PM
seth98es's Avatar
whoops :P
Old 12-26-2003, 05:19 PM
seth98es's Avatar
Ok I wired up 4 AA batteries and it worked. But I only want 2 AA batts, so how should I wire that?
Old 12-26-2003, 06:48 PM
seth98es's Avatar
Heh I wired up the 4 AA batts and took it for a spin using the Red stage 2 motor and was a tad disappointed. I am used to using the white stage 2 motor, but some of the wires came loose and I couldnt find my soldering iron. I have a larger capacitor, but am I supposed to replace the smaller tan capaictor on the motor?
Anyone know why my car feels slower? I havent takend it outside(just ran it around my kitchen) but I couldnt get the tires loose at all. These batts are 2000mAh a piece compared to the 700mAh AAAs I was using.
Old 12-26-2003, 08:17 PM
RC 2NR RC 2NR is offline
TinyRC XModder
The reason why its slower is because a AA has the same voltage as a AAA, so all your doing is adding weight.
Old 12-27-2003, 12:40 AM
seth98es's Avatar
Makes sense, but would a larger capacitor be able to take advantage of the larger mAh?
Old 12-27-2003, 07:16 AM
red02zx3 red02zx3 is offline
The only thing your doing by adding the AA's is increasing the run time. The weight is going to slow you down. The capacitor is for the voltage.
Old 12-27-2003, 11:56 PM
pbmax's Avatar
pbmax pbmax is offline
Li-Ion Addict
Capacitors are normally used (in this case) to clean up voltage. They insure that voltage to the motor (among other things) remains relatively constant and stable. I believe they also reduce the amount of noise the motor throws back into the system.
I didn't do very well in Microelectronics in school...one of the reasons I went digital instead of analog So I may be completely off-base!
pbmax
Old 01-05-2004, 07:29 AM
4 Duracells: 6V=dont need the 6 cell mod!
4 rechargables:4.8V
6 rechargeables:6V/AKA 6 cell mod
6 Duracells: 9V= too much Volts!
Old 01-05-2004, 10:53 AM
Jofir Jofir is offline
Send a message via ICQ to Jofir
so if I put rechargables in my car instead of duracell's
then my car will be slower???
Old 01-05-2004, 12:08 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
no because rechargeables can put out more current than alkalines so it makes up for the lost voltage by dumping out more current and believe me, once you go rechargeables, you wont' go back to alkalines
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-05-2004, 12:21 PM
tavisjohn's Avatar
RC Tinkerer
That is EXACTLY what I encountered! My car would barely run on carpte, till I got IC3's. now it hauls !!!
Old 01-05-2004, 06:45 PM
STR8_UP STR8_UP is offline
Send a message via AIM to STR8_UP Send a message via Yahoo to STR8_UP
how about putting in one 9v batt.?
Old 01-05-2004, 06:59 PM
SupraRacer17 SupraRacer17 is offline
Send a message via AIM to SupraRacer17
9v
hey i think that 9v is too much voltage
Old 01-05-2004, 07:41 PM
Joey's Avatar
Joey Joey is offline
The stock FET(s?) are only good up to 8.4V.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Wiring Help!!! TheBlueYenko ZipZaps SE 0 02-13-2004 05:11 PM
Upgraded Wiring mystiquesupra XMODS Mods and Projects 13 02-05-2004 11:36 AM
wiring soopergooman ZipZaps Gallery 2 01-17-2004 05:54 PM
help, i need a picture of controller curcuit wiring MTL Bit Char-G / MicroSizers 3 12-28-2002 09:43 PM
A question on pcb wiring DabEAn Bit Char-G Mods and Projects 4 11-25-2002 10:36 PM
