12-26-2003, 09:16 PM
vaseline good for gears?
well, i have taken my car apart, and it was very dirty. i cleaned out everything. every last little peice. so now, its as dry as the sahara desert. it still doesnt have much friction due to the metal bearings which is a good thing, but the gears are loud and dont perform very well. i was wondering what i should use to lubricate it. i have alot of vaseline, but is that good to use?
12-26-2003, 09:45 PM
use graphite... from a pencil, it works well for me
12-26-2003, 11:06 PM
so how would i do that. should i hold it in the air and jab the pencil end in? would that work?
12-26-2003, 11:39 PM
no they sell it at hobby shops in a little tube, its ground up like a powder and really works great
12-26-2003, 11:59 PM
Or maybe you can just buy a pack of lead for a lead pencil and smash it up  . And no you should not use vasiline because it will attract dirt and the dirt will stay them and grind into your gears and mess them up.
Xmods Civic:
12-27-2003, 12:28 AM
you should not just smash up a pencil you could possibly make it into a powder as fine as it is sold in.
12-27-2003, 01:54 AM
you think hobby town usa would have em?
12-27-2003, 03:41 PM
how does graphite work well? isnt it just little tiny minerals? isnt little tiny minerals the kind of stuff you dont want getting in your gears?
12-27-2003, 09:20 PM
nah, its not bad for it at all..
12-27-2003, 09:32 PM
"Its OK I had subway"
Wut does it exactly do then?
12-27-2003, 09:33 PM
it creates less friction which makes it spin smoother, if you dont want to try it you dont have too. my car has metal bearings and i used graphite spray on every one, and it has ran smoothly for the past 2 days non stop practically and it runs perfect.
12-27-2003, 10:22 PM
i have been hearing nothing but good about them, so i guess i will pick up some soon. but i have 1 final question. since the metal ball bearings come pre-greased, wouldnt it be bad to use graphite since it will get stuckk all over the grease contained in the bearings?
12-27-2003, 10:24 PM
you dont put it in the bearing, just on the inside, outside part... the middle part where the axle spins in the bearing.
12-27-2003, 11:28 PM
Li-Ion Addict
Has anyone tried WD40 in the gears? Worked great in my combat digi-q, once upon a time. Doesn't attract gunk as badly as vaseline does.
pbmax
12-27-2003, 11:41 PM
wd40 has more chemicals which may be harmful to any plastics on the car...oil is such a mess, it gets spun out everywhere on the car and my car is in every single piece possible soaking in soap water right now.
