Old 12-23-2003, 03:19 PM
Drag00n Drag00n is offline
Are LXX axles exact same as BCG axles?
I need to know because I might buy a LXX car and take its crome wheels and replace them with my BCG crome wheels. Are they the exact same... and do they both use the same material? Cause I know that bit char-A crome wheels are made with some very cheap plastic...
Old 12-24-2003, 07:40 AM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
Not only are they the same, they'll make your Lxx run a lot quieter & smoother. Be sure to use the BCG idler gear also.
DarkTari
If It Don't Fly....."MODIFY"!
Old 12-24-2003, 02:01 PM
Well the reason is...
Well.... I want to replace my BCG wheels with some LXX wheels... because my BCG crome wheels are all scractched up... So ur saying the LXX wheels are EXACTLY the same as the BCG 1s?
Old 12-24-2003, 03:56 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
Sounds like he's saying that theyy will work but they wont be as smooth.
Old 12-24-2003, 08:50 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
LXX are probly the only clone that manages to be almost better than the original.......the axels are very good and work as good as the BCG ones........
-Andres
Old 12-26-2003, 08:58 PM
DarkTari's Avatar
BitPimp Enforcer
Exactamudo!
In my experience, the Lxx gears are not as well manufactored as the BCG. They are loud and don't mesh as well as he BCG/MS.
DarkTari
Old 12-27-2003, 02:33 PM
lucas lucas is offline
I would agree with DarkTari on this all of my LXX cars have been noisy and some have slightly bent axles and if you want to get a new axle just buy the speed kit at toyeast it's cheaper and will probably work better
The minute I find something cool to say it will be here
Old 12-27-2003, 09:45 PM
DarkTari's Avatar
BitPimp Enforcer
Or pick up an MS speed kit from TRU, they're clearing them out now along with body kits.
DarkTari
lxx vs BCG schmock Bit Char-G Parts and Hop-Ups 8 01-03-2004 11:28 PM
