Old 12-26-2003, 07:23 PM
Tdevil Tdevil is offline
SE controller you can get a grip on
I took a 4 inch piece of 1 1/2" inside diameter vinyl drain tubing from Home Depot and wedged it onto the end of the handle. I then cut a piece and wedged it onto the wheel. I had to notch it a bit around the on/off switch and had to build up the wheel on the controller with some tape to make it fit. 1 1/4" tubing would work better on the wheel and you wouldn't have to build up the wheel.
Works great. I can actually drive the car and my hand doesn't hurt. Very comfortable. You do have to put your finger to the outside of the trigger instead of in it to get full throttle travel.
Old 12-30-2003, 08:21 PM
charliebrown's Avatar
That is very creative dude! And it's like a real RC controller!
If only these things were FULLY propo. Oh well..... That's what you get when you purchase from RS. (No offense CJ )
Chuckster...
Old 01-01-2004, 05:36 AM
Real Cars Suck
Well Kimbrough does sell this:
Im not sure it would fit though. What about the rubber tape they use on bike handles?
Controller trouble... Sleeping911 ZipZaps 0 06-25-2004 12:33 AM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 05:12 PM
ZZ controller breakthrough! GryphicRacing ZipZaps 6 10-04-2002 03:22 PM
Sucky Booster Controller aballen Bit Char-G Mods and Projects 3 09-28-2002 06:19 PM
