Old 12-23-2003, 01:28 AM
lam lam is offline
Send a message via Yahoo to lam
should i get a microszers pro?
hello i have a regular microsizers and im thinking about getting the ms pro i heard that it just uses half the power then when you push the button it just gos to full power to seem like a boost but is it really a boost and make the car actually go faster then regularly or is just a rip? i really appreciate the help
Old 12-23-2003, 05:16 AM
strider_mt2k
Correct, they aren't any faster, just two-speed.
A common mod for this is to reverse the action of the boost switch so that it runs flat out all the time, and then slows for corners, etc when the button is pushed.
I think after Christmas I might try a MS Pro. They seem cool.
Old 12-23-2003, 11:12 AM
lam lam is offline
ok
ahhhh ok i get it thanks much
Old 12-23-2003, 12:28 PM
JackD JackD is offline
ITCOB
I have a bunch of MSPRO/Booster 2 spds. They're great. Especially with dual cells and FET mods. The 2 speeds allow you to control the power increase better.
Old 12-23-2003, 12:45 PM
lam lam is offline
whats an FET and are dual cells the two battery thing and if so does it really make the car go faster?
Old 12-26-2003, 08:00 AM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
ive got 2 ms pros, you cant go wrong with the boost!........i would get another (the Evo) but they are out of stock!!!............
-Andres
Old 12-30-2003, 02:36 AM
eetoi's Avatar
eetoi eetoi is offline
Hardcore Otaku
Pro schmo! Who needs a 2 speed? It's all in the thumbs, and how fast you can click the buttons.... Of course, there's always repetitive motion injury
Old 01-02-2004, 09:11 PM
fish fish is offline
SHIFT_micro
Send a message via AIM to fish
how do you do that? got a how-to? thanks in advance!
Old 01-03-2004, 08:11 AM
strider_mt2k
Try a seach here at Tiny RC on that subject. I think there are pics too, dunno.
Old 01-03-2004, 08:33 AM
SHIFT_micro
yea, i did a seach with no luck...not sure exactly what it is called or anything specific.
anyone know where i can find details?
Old 01-03-2004, 12:21 PM
strider_mt2k
I didn't have much luck either.
I haven't done the mod personally, so I don't have any specific details.
If it was me, I'd carefully disconnect the two wires from the pushbutton, buy a tiny normally closed pushbutton switch from Rad Shmack, connect the wires to it and mount it in an appropriate place on the controller.
The normally closed switch will keep the car going fast until you push it, then the car will go slower. Just the opposite of what happens now.
It's probably not what you were hoping for, but I hope it helps.
Old 01-03-2004, 03:10 PM
crrgr's Avatar
crrgr crrgr is offline
Send a message via Yahoo to crrgr
Question
Strider will that work? And wld that be a switch that stays down or up or is it some thing that you must hold down?
Toyota supra 2.2 motor light blue gears!
iWaver PRO FETs Revealed! aaron Mini-Z - Mini-ZRacer.com 0 12-17-2004 08:33 PM
Microsizers Pro vs Microsizers ilkera Bit Char-G / MicroSizers 5 10-30-2003 10:46 PM
Pro vs. Sport??? Bowtied Bit Char-G / MicroSizers 13 09-03-2003 08:05 PM
Got a Microsizer Pro from Toys R Us crazydave Bit Char-G / MicroSizers 5 04-02-2003 11:45 PM
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
