Old 12-21-2003, 07:42 PM
RacerDeX RacerDeX is offline
The Drift King
Send a message via ICQ to RacerDeX
Steering.
I want very tight precise steering the spring upgrade-bearing upgrade ( soon the all wheel drive upgrade ) will be enuff for tight a** steering? like turn on a dime hehe mine turns on a us dollor peice ( a silver dollor hehe )
so can you guys help me out????
Xmods Owned
1x.Acrua RSX
1xSupra
MicroSizers Owned
1xSkyline GTR
1/10th Scale Tmaxx New Edition
1/10th Scale RS4 PRO FullyLoaded
1/18th Scale Mini T
Old 12-21-2003, 10:46 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
the only thing i know to do is use the 4.5* toe-in. or you could mod one to your likeing. btw, the bearng upgrade will only make you go faster, not turn better. (pretty sure anyway)
Old 01-20-2004, 12:49 PM
teamdeadbunny's Avatar
teamdeadbunny teamdeadbunny is offline
Track Master
Agree with RSXRacer - use the 4.5 toe in steering doohickey for tight steering. Just beware that it will be tighter in one direction than the other. Can be a problem when running a direction with the car where you can laterally exceed the tires traction very easily.
Team Dead Bunny Racing
Old 01-23-2004, 02:09 AM
codedat
These guys are correct. a 4.5 tie rod is needed to have tight steering. AWD will help keep the car from fliping over.
Old 01-24-2004, 01:02 AM
jaubery jaubery is offline
Awd will not keep your car from flipping. To do that change to softer springs.
Old 01-24-2004, 10:41 AM
softer springs? are you sure about that? the softer they are the more grip you have, the more grip you have makes it more likely to flip. seems like it would be harder springs to me.
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 03:42 PM
I'm coming back just this once to help with the steering.... charliebrown ZipZaps SE 35 02-26-2004 10:11 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 01:16 PM
Steering Help ZipRC ZipZaps SE 1 09-21-2003 10:57 AM
Steering issue cdog4w Bit Char-G / MicroSizers 21 12-30-2002 11:20 AM
