Old 12-06-2003, 09:37 PM
xc/zz
Cool Speaker wire antenna
I saw that someone had that guitar strings would be good for better range. I have learned that speaker wire works even better simply take off the old wire that comes w/ it and solder the speaker wire on
Old 12-08-2003, 12:13 PM
GerG GerG is offline
how much range does it give u
Old 12-08-2003, 04:01 PM
inventerboy08 inventerboy08 is offline
Send a message via AIM to inventerboy08 Send a message via Yahoo to inventerboy08
while in a three story house you can control the car on the first floor from the third floor
im not short just verticaly chalenged
Old 12-09-2003, 01:04 PM
does it matter which wire i use because there are too wires. also if speaker wire is good on the car is it better to swist speaker wire around the intenna in stead of some other kind of wire and exactly how far is the range?
Old 12-09-2003, 06:54 PM
i used the silver wire and alot of it (note i did not post the first post but i did do it) chris u better watch your back
Old 12-10-2003, 06:05 PM
???????????? COME ON! u didnt answer my whole question... and so does that mean the silver wire is better than the other?
Old 12-12-2003, 10:41 PM
i dont no i havent tryed the silver the inside of the original zz wire was silver i really dont know use my method trial and error
Old 12-18-2003, 03:11 AM
HebrewHammer HebrewHammer is offline
the silver and copper speaker wires aren't any different accept the color, that is just there so that when you are hooking up your speakers, you don't get + and - mixed up in the transition from receiver to speaker.
Racing is life, the res is just details...
Old 12-18-2003, 05:52 PM
NeewomRX8 NeewomRX8 is offline
I Used Coax cable and it works great
I stripped 8" of coax and soldered it in place on my stock wite and I havent fully seen how far it gos but I drove it in my house down a 15' hallway and into the room at the end all the way to the wall and it worked fine, where as befor I could barely get it halfway down the hall.
Old 12-21-2003, 12:44 PM
The silver and copper wires are different when i stripped mine the copper wire has 4 little wires and the silver has 3. does this mean the copper is better?
_________________________________
And inventer boy i currently have a silver wire on mine and it gives me about 2o foot to even ten foot range and im not happy with it. do u have an adapter atatched too your controller?
Antenna wire fix Gaian XMODS 1 01-05-2004 06:24 PM
what kind of resistors right before the antenna wire? RGM1524 XMODS 2 01-05-2004 08:33 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
26 / 24 / 22? What wire size for the antenna? AceQ Bit Char-G / MicroSizers 1 10-22-2002 04:01 PM
