Old 12-15-2003, 11:41 AM
bdon240 bdon240 is offline
eh my diff/back end
Ok something is messed up on my SL. Just all of a sudden the rear non main drive wheel decided to lock up. So i turned it manually and it popped, making it work again. So it stopped again and this time half of the wheel balance(just what i call it) broke off. Does the AWD kit come with the full rear end so i can replace this? cause now the non drive wheel isnt balanced and kinda wobbles, ok it woobles alot, and it hurting the power and delivery of the power, the steering. If not i guess i need to take it back to radioshack. Ive had nothin but problems out of the rear and then my antenna is broke. Nothin but a pain so far.
In case you are wondering, what i refer to a wheel balance is the cirular black, hard plastic piece before you get to the part where the wheel slides on, after the differential. This one that broke is on the side of the differential.
Just wanting to know if theres anything i can do to fix it, or if the AWD kit comes with a replacement rear end for the car, wasnt sure what is replaced with it.
Thanks
Old 12-15-2003, 11:55 AM
HotCar HotCar is offline
the awd kit comes with a new frontend peice, but just a new differential for the rear end. you can probly special order the part through your local radio shack if u need to.
Old 12-15-2003, 02:08 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
What the heck is the "non main drive wheel" The AWD only comes with stuff for the front end...the only thing that comes in it for the rear is a rear diff. Look at the package or something
Old 12-15-2003, 02:19 PM
damn that sux
as for the non main drive, thats just what i refer to the wheel that doesnt spin with the other under very lite throttle pull.
thx neways
Old 12-15-2003, 02:29 PM
RedRSX's Avatar
Subaru WRX STi
I have no idea what your talking about...both my wheels spin under lite throttle pressure...just as they should. I think yours is screwed
Old 12-15-2003, 05:39 PM
MaxxThrasher MaxxThrasher is offline
I do believe the part your talking about is the drive cup and the AWD kit does have those in it.
Old 12-15-2003, 06:06 PM
its ok, i took it back to RS and they replaced it. w00t
thx neways
bitPimp's 4th Annual Year End Blow-Out DarkTari Bit Char-G / MicroSizers 2 10-07-2006 07:37 PM
Tab lowering enfini + question at the end tobenjunk ZipZaps SE 7 04-06-2004 08:42 AM
Stock rear end better? slotsurfer Auldey (All) 1 01-04-2003 03:26 PM
Mini x Loose Front End Hollywood Mini-X 4 06-15-2002 10:47 AM
