12-15-2003, 11:41 AM
eh my diff/back end
Ok something is messed up on my SL. Just all of a sudden the rear non main drive wheel decided to lock up. So i turned it manually and it popped, making it work again. So it stopped again and this time half of the wheel balance(just what i call it) broke off. Does the AWD kit come with the full rear end so i can replace this? cause now the non drive wheel isnt balanced and kinda wobbles, ok it woobles alot, and it hurting the power and delivery of the power, the steering. If not i guess i need to take it back to radioshack. Ive had nothin but problems out of the rear and then my antenna is broke. Nothin but a pain so far.
In case you are wondering, what i refer to a wheel balance is the cirular black, hard plastic piece before you get to the part where the wheel slides on, after the differential. This one that broke is on the side of the differential.
Just wanting to know if theres anything i can do to fix it, or if the AWD kit comes with a replacement rear end for the car, wasnt sure what is replaced with it.
Thanks
12-15-2003, 11:55 AM
the awd kit comes with a new frontend peice, but just a new differential for the rear end. you can probly special order the part through your local radio shack if u need to.
12-15-2003, 02:08 PM
Subaru WRX STi
What the heck is the "non main drive wheel"  The AWD only comes with stuff for the front end...the only thing that comes in it for the rear is a rear diff. Look at the package or something
12-15-2003, 02:19 PM
damn that sux
as for the non main drive, thats just what i refer to the wheel that doesnt spin with the other under very lite throttle pull.
thx neways
12-15-2003, 02:29 PM
Subaru WRX STi
I have no idea what your talking about...both my wheels spin under lite throttle pressure...just as they should. I think yours is screwed
12-15-2003, 05:39 PM
I do believe the part your talking about is the drive cup and the AWD kit does have those in it.
12-15-2003, 06:06 PM
its ok, i took it back to RS and they replaced it. w00t
thx neways
