11-11-2003, 06:05 PM
Cross Drilled brake rotors and calipers for looks
Aluminum screws because they are lighter than Ti.
Metal wheel bolts.
Parts containers and racks for easy, organized parts swap outs.
And maybe a kit that containes everything you need to wind and build your own custom motor.
Aluminum ring gears
Carbon wings to match the hoods
Carbon mirrors
PEACE
If your going to grab the shark by the tail, you'd better have a plan for dealing with the teeth.
11-11-2003, 07:44 PM
PPG Co-Owner
all the little servo/gear plastic made out of metal.
at least metal lining of the screwholes in plastic, because if you havent noticed, it doesnt take much at all to strip the PLASTIC threads
separate body mount tabs that go in the car, so you could buy your own car model and convert it to an XMOD easily
11-14-2003, 02:27 AM
A seprate power supply for the lights. Like a watch battery or somthing.
11-19-2003, 07:24 PM
SHYMERLOO!!!!
don forget a nitrous system, hydraulics, 6 speed manual transmission, underglow(standard), wireless motors just like bit char-gs, real disc brakes that actually work, spinning rims, a carbon fiber hood and chassis, sound system, smoke exaust, opening and closing doors; hood; trunk, aluminum gears, and belt drive.
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
11-19-2003, 09:18 PM
0reZepyT
haha, belt drive. that slack and the stretchability of the belt would act like a slingshot. gun the throttle and it'll probalby zoom off after a couple seconds of getting tension in the belt. not to mention they break easily
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-20-2003, 10:45 PM
ZZMT User
-a 6 speed trans? .... HOW?
-underglow lights pretty simple, buy a light kit (if you don't already have one... buy the LEDs from RS and attach them as you would if you were adding multiple lights... that's how I did mine
-real disc brakes that work? I'm not knocking it , it would be cool , but it would be overkill in my book, unless you had something like a non-abs lock up the wheels kinda brakes
-spinning rims? already made
- c/f hood? It's not a real c/f hood but I have one (the stock one) that's c/f
-c/f chasis? I'd love to see it
-sound system? a fake sound system? or a working sound system? a fake one would be kinda neat to see a set of 12s in the back deck
-doors? I don't see a point since the only thing inside the car is the actual parts of it
aluminum gears? YES!
-belt drive? no!
-some new mirrors? let's get some M3 style mirrors!
-more people in my state that want to have Xmod G2Gs !!!
I'm not trying to say any idea is a bad idea... I'm just stating my opinion. I hope no one takes offense to this.
Xmods: RSX, '04 Cobra R
ZZs:Skyline,S2k (pink),Hemi, Yenko, Camaro SS, RX7 (red), S2k (yellow)
ZZSEs:Mustang GT(Sivler),AE86 Corolla, AE85 Toruno
ZZMT: BigFoot
12-01-2003, 07:04 PM
Skyline=Sweet
Originally posted by turbopimp187
sumkinda digital nitrous. like small batteries that are incased in a nos bottle with a braided wire to the motor for a realistic look and feel.
That gave me an idea, but I probably can't do it. You could make a small Nitro bottle with space for 1 watch-battery-type-thing that's re-chargable. You put a battery in the casing and there's a little wire with a T-plug at the end. You know that plug that connects the motor and the battery wires? The T-plug could go right there, and also there would be a wire running to the antenna. The battery, when a button (more on that later)on the controller is pressed, the battery starts and gives an rpm boost to the motor. It's like Nitrous, but without fire!  Then there's a hard part. You'd have to rip apart the controller and drill a hole, maybe where your pinky would go. You could go to RS and maybe(maybe)maybe find a button that sends a signal through wires and through the antenna to start the batteries.
12-01-2003, 09:13 PM
like my dog??
i would love to see all of the drivetrane parts made out of mettal!! it would be heavyer but would never strip.
ohh, yeah and a new type of drivesaft design, the 3/4 circles just dont cut it! the round themselfs out!
--Chris
Aka...aero528
12-03-2003, 09:49 AM
anodized T-106 aluminum chassie and maybe some aluminum wheels? cause i broke the spokes on my wire wheels...
oh yeah motors like the SBP but allready together and not 50.00 bucks.........
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
12-06-2003, 03:31 PM
Skyline=Sweet
I wanna see body top kits that come with body kits, maybe like 19.99 altogether.
12-10-2003, 12:58 AM
A 9 volt battery kit with all the resistors needed to run it and not burn out the stock PCB. Or even Better a 9v X2 Battery kit with replacement PCB that will hadle 18 volts
A heat sink that actually works.
Real Functioning Swaybars.
Light weight Chassis.
A body with see through windows and interior
Light Kit add ons like strobing headlights or functioning turn signals.
Liscense Plates
A Minni Dynomometer Built to scale. So it read 800 hp... 900hp and not .03 hp. Aslo able to read Maximum Speed in MPH and in scale.
A cleaning Kit with all necissary solvents and Lubes.
Drive Shaft Kits
Aluminum Suspension Parts. Swing arms... A arms, all of it.
Toe Bars that don't have 1/64" of play in them.
Flywheels
Replacement: More acurate Steering Box
Tires that don't fly off
Loud doesn't = fast.
Import doesn't = quality.
Chrome Doesn't = performance gains
Clear Tailights just make you easier to spot.
My 4 cylinder has 210 Natural aspirated HP is only 2.3 li, and is 15 years old, and it was built right here in the good ol' USA.
